deadlock during debug
Isabela_Z_
Hi everybody,
I'm trying to find where inside my program appears the first NaN var.  So I created the following function:
logical FUNCTION testanan(var)
implicit none
real(8) var
if (var /= var) then
    print*, 'deu NAN na', var
    TESTANAN=.TRUE.
    READ(*,*)
endif
ENDFUNCTION
I run in debug mode and when the message appears in the screen, I press pause to find out in which line the NaN appears. But when I do that, deadlock happens...
How can I identify where is my first NaN happens?
jimdempseyatthecove
Why not remove the READ and place a debugger break point on TESTNAN=?
Then when break is hit, single step out of the function.
Jim Dempsey
mecej4
I second Jim's comments.
NOTE: If "var /= var" is false, the function value is undefined.
Isabela_Z_
Thanks a lot Jim, I will try your suggestion and I gonna fix the result.
Best regards
Please don't use var /= var to test for NaN. Use the intrinsic IEEE_ISNAN from intrinsic module IEEE_ARITHMETIC. The compiler might choose to delete your comparison under normal optimization. If you want to do such tests, you must compile with the option /fp:strict
