deallocate in Select Type
StevenGamm
Hello, I'm trying to use deallocate in the Select Type structure, but this is not true:
error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute.
I have to use the code in comment lines, but that makes the code redundant
Gfortran compiles and runs the same code.
Thank you!
Module typedef
implicit none
type :: T_Main
end type T_Main
type , extends(T_Main) :: T_Sub
contains
Final :: fn
end type T_Sub
contains
Subroutine fn(this)
type(T_Sub) , target :: this
write(*,*) "Final it!"
End Subroutine fn
End Module typedef
program main
use typedef
implicit none
class(T_Main) , pointer :: pMain
type(T_Sub) ,target, allocatable :: pSub
!type(T_Sub) , pointer :: pSub2
allocate(pSub)
pMain => pSub
Select Type( pv => pMain )
Class Is( T_Sub )
!pSub2 => pSub
!deallocate(pSub2)
deallocate(pv)
End Select
end program main
FortranFan
@StevenGamm ,
As shown in the original post, the code does not conform to the Fortran standard.  Intel Fortran conforms to the standard by issuing a diagnostic.
Given the Fortran standard and the tremendous benefit it provides with the ALLOCATABLE attribute on objects, one does not need explicit finalization, explicit "garbage collection" in the form of DEALLOCATE, etc.  If you post your use case here (or at Fortran Discourse https://fortran-lang.discourse.group/ on all matters pertaining to Fortran generally), readers may be able to guide you to other, possibly simpler solutions that position you better than the one above where another Fortran compiler disagrees with the standard and causes you doubt.
Steve_Lionel
That is the correct behavior. Quoting the standard (emphasis mine):
Within an ASSOCIATE, CHANGE TEAM, or SELECT TYPE construct, each associating entity has the same rank as its associated selector. The lower bound of each dimension is the result of the intrinsic function LBOUND (16.9.109) applied to the corresponding dimension of selector. The upper bound of each dimension is one less than the sum of the lower bound and the extent. The associating entity does not have the ALLOCATABLE or POINTER attributes; it has the TARGET attribute if and only if the selector is a variable and has either the TARGET or POINTER attribute
