debug assertion failed
sunshine177
my code generated the following error messages.
1.
Debug Assertion Failed!
program...
File:winsig.c
Line:419
Expression: ("Invalid signal or error",0)
2.
forrtl: severe <170>: Program Exception - stack overflow
Someone in this forum asked the same question ->http://software.intel.com/en-us/forums/showthread.php?t=66306
I guessed this is a problem of stack size, so I increased the Stack Reserve Size(100MB), stack commit size(100MB),heap reserve size(100MB),heap commit size(100MB), but it's not still working.
My laptop is 32-bit. I am using Intel Visual Fortran v11.1 and Visual Studio 2005.
I cannot run the code in 32-bit computer?
Anyone can help me with this?
Xiaoping_D_Intel
The error message shows it is stack overflow error. Have you tried "-heap-arrays" as Steve Lionel told in post #66306?
sunshine177
I made object files and modules and then I typed the following
ifort [object files] -o main -heap-arrays -I"[library path]" [library files]
But the result is the same
->severe <170> : program exception - stack overflow
Anyone can figure this out?
Wendy_Doerner__Intel
Valued Contributor I
You can also write over the stack on your own. One way to check for coding errors is to add /check to the compiler to add runtime checks.
Wendy
Attaching or including files in a post
sunshine177
Could you show me how to write over the stack on my own? I don't have much knowledge about CS. sorry.
Xiaoping_D_Intel
"-heap-arrays" should be applied to each compilation command line used to make object file.
Xiaoping_D_Intel
I think Wendy means writing over the stack by yourcode may also be a possible reason for the failure. To check such case you can add "-C" option (Here 'C' is uppercase) to your compilation command lines to enable runtime check.
