29564 讨论
debug issues apparently not resolved in 2026.0
mph13
初学者
257 次查看
I recently switched to ifx and oneAPI, and the latest 2026 version. This version has debugger problems that people have raised last year.
1. Watches and mouse over variables are not valid if the case of the variable does not match.
2. The test for uninitialized variables has not been implemented.
If the recent version has fixed this with some switch, please let me know. Otherwise I hope a fix will come eventually.
0 项奖励
1 解答
Steve_Lionel
名誉分销商 III
207 次查看
@mph13 , your symptoms suggest to me that the Fortran debug support has not properly installed, and you are getting the default C support instead.
In Visual Studio,  select Extensions > Manage Extensions. Search for Fortran. If the "Intel Fortran Expression Evaluator says it is installed, uninstall it, exit VS, then go back in, repeat the above search and install it. Ignore the extension named "Intel Fortran Compiler".
在原帖中查看解决方案
4 回复数
Steve_Lionel
名誉分销商 III
208 次查看
mph13
初学者
202 次查看
@Steve_Lionel
Thank You! In fact, my extensions show that Intel Fortran Compiler and the Fortran Expression Evaluator were not installed. I installed the Evaluator and indeed that fixed the case sensitive problem.
Should the Intel Fortran Compiler extension also be installed? Why is my solution compiling ok without it?
0 项奖励
Steve_Lionel
名誉分销商 III
200 次查看
Yes, both extensions should be installed, though to be honest I don't know what the Compiler extension does. It would not hurt to install it as well.
0 项奖励
mph13
初学者
195 次查看
When attempting to install the Intel Fortran Compiler extension, it downloads an install file, then nothing further happens. So I close VS and run the downloaded intel-fortran-compiler-2026.0.0.566.exe. That opens to show me that the Fortran Complier is already installed. Perhaps the extension and the actual 2026.0 compiler are the same thing and the extension is redundant in this new 2026 version?  I cannot get the Intel Fortran Compiler extension to show "Installed" in VS.
Thanks for your help. I will ignore the extension installation.
0 项奖励
回复
