I have a problem in that I have have some static libraries that were written several years ago and compiled on 32 bit machines. The person who wrote these for me is now dead and I can't get the orginal source for the libs. I'd like to recompile these into 64 bit. Is there a way to decompile and then recompile into 64 bit?
链接已复制
2 回复数
You are using FORTRAN
Fortran has available OpenMPI.
You could use OpenMPI and split your FORTRAN program into two processes. One process as 64-bit, the other process as 32-bit. And where the 32-bit contains the code that calls the 32-bit static libraries.
This might be easire to implement than to try to reverse assemble a 32-bit library and also easier (for an inexperienced programmer) than trying to impliment your own messaging system using a memory mapped file.
I consider you investigate OpenMPI.
Jim Dempsey
Jim Dempsey
