#define and explicit type
bgswri
Good Afternoon,
I am attempting to compile a program which was forwarded to me on CVF v6.6B. The program contains
several include files with #define statements. During the build, I get errors indicating the parameters from the #define directives need explicit type definitions. In the past, I have understood the #define directive to be a parameter definition which substitutes the value for the symbol in subsequent calls.
I have checked the Use FPP box in the compilier settings, but I can't get the program to compile.
Here is an example of the code - without the include file
Program main
implicit none
#define ISY_MAX 45
character csytst(ISY_MAX)*15
end program main
Any suggestions would be greatly appreciated.
Thank You,
Brian
james1
Yes, macro expansion is off by default. You need to add the "/m" option to the /fpp switch to get what you are expecting.
James
