delete a file
ekeom
I would like to know how to delete a file (located on the hard disk) using visual fortran.
Didace
TimP
Did you try the UNLINK library function? In Windows, it does require that the file you want to delete should be closed first.
There are various ways to do this on Windows.
The DELFILESQQ library routine would be easiest, though you can also use UNLINK. You'll want to add USE IFPORT to the source. One can also do a CLOSE with DISP='DELETE'.
ekeom
Thank you very much, I had done it using the UNLINK function.
Didace
