detect bad array shape
Roman1
The following program has a bug.  Do you know if it is possible to have the compiler detect it?  I have tried the following options without success:
/Qtrapuv /Qinit:snan /Qinit:arrays /fpe:0   /check:all
program test_shape
implicit none
real,allocatable,dimension(:):: a, b
real c
allocate( a(5), b(2) )
b = 0.0
a = b   !!!
c = a(3)
print*, c  ! output: -4.3160208E+08  ???
stop
end program test_shape
NotThatItMatters
That is not a "bug".  The a array's first two entries are being set to the values in the b array.  As should be expected, the third entry is not initialized.  Therefore, it has a value that cannot be predicted.  About the only thing you can do here is have the compiler initialize the array.
FortranFan
Are you aware of /assume:realloc_lhs and/or /standard-semantics compiler options and the role they play with treating allocatable objects?
https://software.intel.com/en-us/node/579519
https://software.intel.com/en-us/node/579529
You'll notice per standard Fortran i.e., starting with Fortran 2003, SIZE(a) should be 2 following the assignment on line #10, not 5 as allocated on line #7.  But if I'm not mistaken, standard Fortran rules for allocatable object assignment, etc. are still not implemented by default in Intel Fortran, rather one has to turn them on using /standard-semantics, etc.  So you may want to look into this aspect and whether you are making use of it; if not, see if you can and should.
Now if you go with standard Fortran rules for reallocation, you can look into /check:bounds compiler option which can trigger a run-time check when line 12 is executed since it should involve accessing an element outside the bounds, something worth doing with tests on your code run in Debug configuration:
https://software.intel.com/en-us/node/579521
Otherwise, look into /check:uninit and /check:pointers and whether they can help you, at least at run-time if not at compile-time.
Roman1
Thanks for the information!  Initially, I was hoping that since I used  /Qinit:snan /Qinit:arrays , the value of c would be set to NaN, instead of -4.3160208E+08 .  The /assume:realloc_lhs  option was helpful.
