devenv 2005 crash
Martin__Paul
I am compiling a VS2005 solution which comprises a number of Fortran (10.1.011 compiler) and C++ projects.
Building using devenv /Build from the command line is successful. However, VS crashes when running a build from a Cruise Control build server immediately after successfully building all projects. I have extracted a crash dump using Debug Diag which reports the following:
the assembly instruction at VFProj+2e0bf in C:\Program Files\Microsoft Visual Studio 8\Intel Fortran\VFPackages\VFProj.dll from Intel Corporation has caused an access violation exception (0xC0000005) when trying to read from memory location 0x00e7c0a4 on thread 0.
Thread 0 - System ID 4080Entry point devenv!WinMainCRTStartup
Create time 05/08/2009 17:15:23
Time spent in user mode 0 Days 0:0:2.125
Time spent in kernel mode 0 Days 0:0:7.62
FunctionArg 1Arg 2Arg 3Source
VFProj+2e0bf 4d23a4f0 05f15cc8 00e7ef30
VFProj+2e7b0 4d23a4cc 00000000 00e7ef30
VFProj+26bc0 0628aa68 00000000 05f15cc8
msenv!ATL::CComPtr&ltCGoBa= ckMarker>::~CComPtr&ltCGoBackMarker>+24
00000000
00000000 00000000
Is this a known issue, and if so, is there a workaround? I am unsure whether the cause of this behaviour is a problem with VFProj.dll or devenv.exe.
Please advise.
Thanks in advance.
This problem is not familiar to me, but 10.1.011 is an old version. Try installing 11.1 - you can use the 11.1 Visual Studio integration with the 10.1 compiler (though I would ask that you get a more recent 10.1 as you have the initial product release and we fixed many issues after that.)
Martin__Paul
Thanks. Can I download the 11.1 VS integration to see if it fixes the problem? I do not have the 11.1 compiler. (A search of your download site and the internet returned no hits).
Martin__Paul
I have installed v11.0 with MVS2008 and will let you know how I get on.
Martin__Paul
Installing Fortran 11.1 and VS2008 has worked around the issue.
