dialog box
salem__arezki
hi,
i'm using the resource editor to create a calucator program, so when i run the program all are ok, then when i display a dialog box and put all data of my problem then i validate the data and close the dialog box, when i re open it all the data are deleted and initilized to the initial value !
so what shall i do to keep my parameters even after closing the dialog box ?
Arezki Salem
reidar
New User
Check the property of your project: Project - > property -> Fortran -> Data.   At the "Local Variable Storage" ensure that the switch is set to "All Variables SAVE (/Qsave)
Otherwise you can apply the SAVE statement directly in your sub-routine. See Fortran documentation.
