29391 Discussions
ERROR #7061 when compiling the subroutine using Intel compiler 18.0
Sun__Rui
I got this issue when compiling the coupled code using Intel compiler 18.0:
mod_esmf_atm.F90(70): error #7061: The characteristics of dummy argument 1 of the associated actual procedure differ from the characteristics of dummy argument 1 of the dummy procedure.   [ATM_INIT1]
It seems that the interface of the subroutine is not consistent that in ESMF:
 68       call NUOPC_CompSetEntryPoint(gcomp, ESMF_METHOD_INITIALIZE,       &
 69                                    phaseLabelList=(/"IPDv00p1"/),       &
 70                                    userRoutine=ATM_Init1, rc=rc)
 71       if (ESMF_LogFoundError(rcToCheck=rc, msg=ESMF_LOGERR_PASSTHRU,    &
 72           line=__LINE__, file=FILENAME)) return
 96       subroutine ATM_Init1(gcomp, importState, exportState, clock, rc)
 97
 98       TYPE(ESMF_GridComp), TARGETINTENT(inout)  :: gcomp
 99       TYPE(ESMF_State),    TARGETINTENT(inout) :: importState
100       TYPE(ESMF_State),    TARGETINTENT(inout) :: exportState
101       TYPE(ESMF_Clock),    TARGETINTENT(inout) :: clock
I can compile this code on using an older Intel compiler (13.0 and 16.0). And some other people also reported a similar issue: (some other people also reported this issue). Do anyone know how can we compile it?
I rewrite the code like this:
 97
 98       TYPE(ESMF_GridComp)  :: gcomp
 99       TYPE(ESMF_State)     :: importState, exportState
100       TYPE(ESMF_Clock)     :: clock
104       INTEGER,                     INTENTOUT) :: rc
105
106       ! Local variables
107       TYPE(ESMF_GridComp), TARGET :: t_gcomp
108       TYPE(ESMF_State),    TARGET :: t_importState, t_exportState
109       TYPE(ESMF_Clock),    TARGET :: t_clock
110       TYPE(ESMF_GridComp), POINTER :: p_gcomp
111       TYPE(ESMF_State),    POINTER :: p_importState, p_exportState
112       TYPE(ESMF_Clock),    POINTER :: p_clock
128
129       t_gcomp = gcomp
130       t_importState = importState
131       t_exportState = exportState
132       t_clock = clock
133
134       p_gcomp => t_gcomp
135       p_importState => t_importState
136       p_exportState => t_exportState
137       p_clock => t_clock
I can compile the new code, but can anyone tell me if the new code will work correctly?
Juergen_R_R
Valued Contributor II
It very much looks like that your code might not be standard-conforming. Your modified subroutine doesn't have (with one exception) intents being defined for the dummy arguments of the subroutine which makes it harder for the processor to detect any error. That could be the reason that this code compiles. Without showing the actual code and all the interfaces for the routines, nothing further can be added.
