dll files not found in Windows 10
dondilworth
New Contributor II
My program requires some dll files, which I install with
w_fcompxe_redist_ia32_2013_sp1.1.139.msm
with Advanced Installer.  The user has to run the msi file, and then the program works.  This runs on XP, and Windows 7.  I upgraded some W7 PCs to W10, and the program still works.  So far, so good.
But if I install everything on a new W10 machine that has never seen my program before, I get a message that the program cannot start because libifcoremd.dll (and three others) are missing.  But the files are indeed on the machine in
C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler.
I checked them, and deselected the read-only attribute, but they still don't work.  Any ideas?
dondilworth
New Contributor II
As you were.  Right-click the .exe file, Properties, Run as Administrator.  Then it works.
dondilworth
New Contributor II
