does assigned go to work as it should ?
e745200
having said that I am removing all obsolete features from the code I am working on, I think there is something incorrect in how Intel Fortran deals with assigned goto statements: it seems to ignore any list of labels.
According to the documentation, "If a list of labels appears, the statement label assigned to the variable must be one of the labels in the list."
Nevertheless, nothing special happens if this is not the case, and the programs flows as if the list of labels was not specified.
A short example will show it.
$ cat tassgoto.f90
      integer :: j
      assign 10 to j
      go to j , ( 1, 2 )
      print *, "d'oh"
      stop
 1    print *, 1
      stop
 2    print *, 2
      stop
 10   print *, 10
      stop
      end
$ ifort -V tassgoto.f90
Intel(R) Fortran Intel(R) 64 Compiler for applications running
on Intel(R) 64, Version 16.0.0.109 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
 Intel(R) Fortran 16.0-1540
GNU ld version 2.20.51.0.2-5.42.el6 20100205
$ ./a.out
          10
Is there something I'm missing ?
jimdempseyatthecove
Steve, is this valid
ASSIGN 10 TO ISOK1 ! 10 is valid label
ASSIGN 20 TO ISOK2 ! 20 is valid label
! I is supposed to be assigned to one or the other
IF(.NOT.((I .EQ. ISOK1) .OR. (I .EQ. ISOK2))) STOP "Bug"
GOTO I,(10,20)
IOW perform an IF statement using assigned integers
If this is permitted, then an "assert" could be inserted into the code to verify code is not doing unexpected behavior.
Jim Dempsey
Steven_L_Intel1
No, not permitted. Quoting FORTRAN 77:
A variable must be defined with a statement label value when referenced in an assigned GO TO statement or as a format identifier in an input/output statement. While defined with a statement label value, the variable must not be referenced in any other way.
The method by which the ASSIGN is done is implementation-dependent. If I recall correctly, VAX FORTRAN-77 would store the address of the labeled statement/format, while DEC Fortran 90 stored some sort of index. We started seeing a small number of customer complaints when their code which assumed an address stopped working - they were saving the address and jumping to it from other locations in the program!
mecej4
Just as we have IF(ALLOCATED(VAR))... and IF(ASSOCIATED(PTR))..., they could have provided IF(ASSIGNED(LABEL))..., but they did not. I have faint recollections of similar language design problems in Fortran 90 that were fixed in Fortran 95.
Steven_L_Intel1
Or they could have removed assigned GOTO from the language - which they did.
e745200
Well, I might seem annoying, but I am keeping on investigating this issue just for my personal curiosity.
I finally found this run-time error message ( https://software.intel.com/en-us/node/525375 ) :
542
severe (542): Label not found in assigned GOTO list
FOR$IOS_F6098. The label assigned to the integer-variable name was not specified in the label list of the assigned GOTO statement.
Is this a residual of a no longer trapped error or there still is a way for activating/implementing the proper run-time-check ?
Was it an intention never implemented ?
I tried using the compiler option -check all but with no result.
Steven_L_Intel1
All I can tell you is that there is no code in the compiler today that will cause this diagnostic to be emitted. Maybe the message definition got brought over from another implementation, though it's not listed in my copy of the VAX Fortran User Manual. Perhaps it was a clue planted by ancient aliens. Dunno.
e745200
That's ok: being projected towards the future, I think we can happily survive to this.   ;-)
Have a great holiday season !
JVanB
Valued Contributor II
Does this mean we can read into a Hollerith field in a FORMAT statement, and then use the ASSIGN statement and assigned GOTO to jump into the code we just inserted there? Why does ASSIGN require a default integer when the address size is 64 bits?
      PROGRAM P
      IMPLICIT NONE
      INTEGER I
      INTEGER K(3)
      DATA K/1836216166,840987745,538976304/
10    FORMAT(12HFORMAT 10   )
20    FORMAT(12HFORMAT 20   )
      DECODE(12,20,K)
      ASSIGN 20 TO I
      PRINT 20
      END PROGRAM P
Steven_L_Intel1
You cannot GOTO an assigned FORMAT label, but you can use it as a format.
Don't assume what is stored is an address. That's what bit the VAX users when they moved to the 64-bit Alpha platform.
