dyld: Symbol not found: _iso_c_binding_mp_c_null_funptr_
Juergen_R_R
Valued Contributor II
Trying out for the first time ifort (19 beta) on MAC OS X with the trial version, up to now I had our software built only on Linux. On Darwin 17.5.0 using gcc (from my own build, not clang) as a CCLD C linker, I get unresolved symbols in my library (cf. below).
On Linux there is one more line
U isoc99 sscanf@@GLIBC 2.7
but the executable does not bother that there are these undefined symbols in the main library. Before I post any more details (let me know which ones you want): any ideas?
00000000060c71c0 s _isl
                 U _iso_c_binding_mp_c_associated_funptr_
                 U _iso_c_binding_mp_c_associated_ptr_
                 U _iso_c_binding_mp_c_loc_private_
                 U _iso_c_binding_mp_c_null_funptr_
                 U _iso_c_binding_mp_c_null_ptr_
Lorri_M_Intel
What does your link line look like?
Juergen_R_R
It seems that the ifort libraries like libirc, libimp, and libsvml had been missing. This is strange, on Linux I do not have to explicitly include them in the linking command in order to get them linked into my application library. Here is the thing that I added explicitly in the link command under OSX:
-L/opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib -L/usr/lib /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libifport.a /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libifcoremt.a /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libimf.a /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libsvml.a /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libipgo.a /opt/intel//compilers_and_libraries_2019.0.041/mac/compiler/lib/libirc.a -lpthread /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/9.1.0/lib/darwin/libclang_rt.osx.a
Then it works.
Lorri_M_Intel
If you are using "ifort" to link your application on Linux, then the compiler-driver knows to add in these libraries.
It sounded from your OP that you were using "gcc" to link your application.    There is no way that gcc would know to add in these libraries.
           Glad to hear that you've resolved it --
                                           --Lorri
Juergen_R_R
Yes, in principle I can link and our code runs. However, the parsing of the command line does strange things different than under Linux. For the linking, is there a well-defined, preferred method to automatically access the list of libraries to be linked into a user library? In our configure I use the -dryrun flag, but that gives me only static libraries under OSX compared to dynamic calls under Linux.
