29563 Discussions
-dynamic: No such file or directory After Xcode update
Peter_M_1
Yesterday I was compiling some fortran code no problem on my mac. Today I performed a system update via the Mac App Store.
After this now when I try and compile the same code using the same command as yesterday I get ..
ifort -assume realloc-lhs triangle_cant_g.f90 -o cant
There was a command line tools update, and an Xcode update, to version 6.0.1, as well as an Mac OS X update ...
Is any one else having these problems, I tried running
source /opt/intel/bin/ifortvars.sh intel64
But this didn't help. Thanks, Peter
I don't remember your mentioning an Xcode update on StackOverflow. If you change Xcode versions, you MUST reinstall Intel Fortran. That said, we don't yet support Xcode 6.
Peter_M_1
Stackoverflow ? I've not posted this there, are there other people having similar problems ? Do you have a link to the SO post ?
I wasn't aware Xcode 6 was unsupported, this however wasn't an update to a major version, rather an update too 6.0.1. It's pretty disappointing if I have to reinstall all the intel compilers every time  there's a minor update...
Sorry - I thought I had seen it there. Somewhere else...
Yes, unfortunately, you do often need to reinstall after each Xcode update. Apple likes to pretend that nobody uses any software that doesn't come from Apple and Xcode updates often wipe out our integration. Some updates might not need this, but it is our general advice.
I'll let our Mac experts comment on your specific problem.
Ron_Green
I have that same OS and Xcode version:  OS X 10.9.5 and Xcode 6.0.1.  I've not had any issues.
the source you have is wrong - needs to be
source /opt/intel/bin/compilervars.sh intel64
-dynamic is an argument we pass to the system linker 'ld'.  Do this to see what linker you have:  here is what I see what do you see?
$ which ld
/usr/bin/ld
rwgreen-mac03:~ rwgreen$ ld -v
@(#)PROGRAM:ld  PROJECT:ld64-241.8
configured to support archs: armv6 armv7 armv7s arm64 i386 x86_64 x86_64h armv6m armv7m armv7em
LTO support using: LLVM version 3.5svn
Now what I want you to do is compile with option -#
ifort -#  -assume realloc-lhs  triangle_cant_g.f90 -o cant
Show me the full output from this command
ron
Peter_M_1
Peters-MacBook-Pro:tri_fem_140925 Peter$ source /opt/intel/bin/compilervars.sh intel64
Peters-MacBook-Pro:tri_fem_140925 Peter$ ifort -#  -assume realloc-lhs  triangle_cant_g.f90 -o cant
/usr/bin/ifort-14.0-base/bin/intel64/fortcom  \
    -D__INTEL_COMPILER=1400 \
    -D__INTEL_COMPILER_UPDATE=3 \
    -D__x86_64 \
    -D__x86_64__ \
    -D_MT \
    -D__INTEL_COMPILER_BUILD_DATE=20140415 \
    -D__PIC__ \
    -D__APPLE__ \
    -D__MACH__ \
    -D__pentium4 \
    -D__pentium4__ \
    -D__tune_pentium4__ \
    -D__SSE2__ \
    -D__SSE3__ \
    -D__SSSE3__ \
    -D__SSE__ \
    -D__MMX__ \
    -mGLOB_pack_sort_init_list \
    -I. \
    -I/opt/intel/composer_xe_2013_sp1.3.166/ipp/include \
    -I/opt/intel/composer_xe_2013_sp1.3.166/mkl/include \
    -I/opt/intel/composer_xe_2013_sp1.3.168/tbb/include \
    -I/usr/bin/ifort-14.0-base/compiler/include/intel64 \
    -I/usr/bin/ifort-14.0-base/compiler/include \
    -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include \
    -I/usr/local/include \
    -I/usr/include \
    "-assume realloc_lhs" \
    -O2 \
    -simd \
    -mP1OPT_version=14.0-intel64 \
    -mGLOB_diag_file=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortJBHJbk.diag \
    -mGLOB_diag_use_message_catalog=FALSE \
    -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
    -mP2OPT_static_promotion \
    -mP1OPT_print_version=FALSE \
    -mCG_use_gas_got_workaround=F \
    -mP2OPT_align_option_used=TRUE \
    -mGLOB_gcc_version=481 \
    "-mGLOB_options_string=-# -assume realloc-lhs -o cant" \
    -mGLOB_position_independent_code \
    -mGLOB_preemption_model=1 \
    -mGLOB_no_compact_unwind=TRUE \
    -mGLOB_cxx_limited_range=FALSE \
    -mCG_extend_parms=FALSE \
    -mGLOB_compiler_bin_directory=/usr/bin/ifort-14.0-base/bin/intel64 \
    -mGLOB_as_output_backup_file_name=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortTaZ0JUas_.s \
    -mIPOPT_activate \
    -mIPOPT_lite \
    -mGLOB_em64t \
    -mGLOB_instruction_tuning=0x0 \
    -mGLOB_product_id_code=0x22006d8f \
    -mCG_bnl_movbe=T \
    -mGLOB_extended_instructions=0x80 \
    -mP3OPT_use_mspp_call_convention \
    -mP2OPT_subs_out_of_bound=FALSE \
    -mGLOB_ansi_alias \
    -mPGOPTI_value_profile_use=T \
    -mP2OPT_il0_array_sections=TRUE \
    -mP2OPT_hlo_level=2 \
    -mP2OPT_hlo \
    -mP2OPT_hpo_rtt_control=0 \
    -mIPOPT_args_in_regs=0 \
    -mP2OPT_disam_assume_nonstd_intent_in=FALSE \
    -mGLOB_imf_mapping_library=/usr/bin/ifort-14.0-base/bin/intel64/libiml_attr.dylib \
    -mIPOPT_obj_output_file_name=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortJBHJbk.o \
    -mIPOPT_whole_archive_fixup_file_name=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortwarchHP4P1E \
    -mGLOB_long_size_64 \
    -mGLOB_routine_pointer_size_64 \
    -mGLOB_driver_tempfile_name=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/iforttempfile446ru3 \
    -mGLOB_os_target=GLOB_OS_TARGET_MACH \
    -mGLOB_async_unwind_tables=TRUE \
    -mGLOB_obj_output_file=/var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortJBHJbk.o \
    -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
    -mP1OPT_source_file_name=triangle_cant_g.f90 \
    -mP2OPT_symtab_type_copy=true \
    triangle_cant_g.f90
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld  \
    -dynamic \
    -arch \
    x86_64 \
    -weak_reference_mismatches \
    non-weak \
    -macosx_version_min \
    10.9.5 \
    -no_compact_unwind \
    -o \
    cant \
    /usr/bin/ifort-14.0-base/compiler/lib/for_main.o \
    -L/opt/intel/composer_xe_2013_sp1.3.168/compiler/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.166/ipp/../compiler/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.166/ipp/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.166/compiler/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.166/mkl/lib \
    -L/opt/intel/composer_xe_2013_sp1.3.168/tbb/lib \
    -L/usr/bin/ifort-14.0-base/compiler/lib \
    -L/usr/lib \
    /usr/bin/ifort-14.0-base/compiler/lib/libifport.a \
    /usr/bin/ifort-14.0-base/compiler/lib/libifcore.a \
    /usr/bin/ifort-14.0-base/compiler/lib/libimf.a \
    /usr/bin/ifort-14.0-base/compiler/lib/libsvml.a \
    /usr/bin/ifort-14.0-base/compiler/lib/libipgo.a \
    -lSystem \
    /usr/bin/ifort-14.0-base/compiler/lib/libirc.a \
    -lpthread \
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortxcrunz5o57Z
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortxcrunrHshSA
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortxcrund3HTIx
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortxcrun0Xgmft
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortgnudirsjF3HOU
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortxcrunOhg1Dj
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortclangdashv4TEuo6
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortJBHJbk.o
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortosGts2iH
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/iforttosiBLayz
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortTaZ0JUas_.s
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/iforttempfile446ru3
rm /var/folders/l1/xy86_dd92x3d3sb460g5czpr0000gn/T/ifortargj95LLk
Peters-MacBook-Pro:tri_fem_140925 Peter$ ifort -assume realloc-lhs  triangle_cant_g.f90 -o cant
ld: warning: directory not found for option '-L/opt/intel/composer_xe_2013_sp1.3.168/compiler/lib'
Although it now appears to compile, although with these new warnings I did not get previously..
Ron_Green
well the above is helpful but note that -# shows all the steps the compiler WOULD DO, but it doesn't actually compile anything.
BUT I think I see what's happening.  So you installed Xcode 6.0.1 the other day.  Since then, have you actually started the Xcode application?  From your Applications folder start XCode.  There is a new step after installing 6.0.1 that requires you to accept a license agreement before it finishing downloading and installing all the command line tools.
So run the Xcode app, accept the license agreement, let it install things, then try the compile again without the -#.
Also, bring up Xcode, go to menu Preferences.  When the Preferences window comes up, go to the Downloads icon/tab.  It should look like this:
Peter_M_1
Ah ha interesting!
I hadn't actually opened Xcode, since I never use it. It started to work again after I fell back to gfortran to do some work. When I attempted to compile with gfortran it told me to run it as sudo, and accept the new Xcode user agreement.
The next time I tried to use ifort, it worked, with the exception of this message
But it compiles and seems to run ok, so I can live with this just now, thanks a lot!
Peter
Ron_Green
As Steve said, I think you need to re-install the latest IFORT compiler so that it'll look for the libraries from the directories of the new compiler and not your old one.
ron
