29607 Discussions
Debugging derived types Composer 15.0 in VS2010
A__Valle
Dear all,
When debugging an extended type that gets the base type form another module, The VS2010 integration gives a syntax error, see the following screenshot
The type is defined as follows:
TYPE, EXTENDS(SL_CaseType) :: SLNK_CaseType
Is there are workaround present to see the contents of the extended type in VS2010?
Dirk
Lorri_M_Intel
That looks like a bug.
Is SL_CaseType declared as Private?
Is there anything else you can share about the characteristics of SLNK_CaseType or SL_CaseType so we can reproduce it here?
        thanks -
                    --Lorri
A__Valle
Simple Reproducer, set breakpoint at appropriate location:
Module BaseTypeMod
  Implicit None
  Private
  TYPE, PUBLIC :: SL_CaseType
    INTEGER :: CaseID
  ENDTYPE SL_CaseType
  End Module
  MODULE DerivedTypeMod
  USE BaseTypeMod, ONLY: SL_CaseType
  Implicit None
  Private
  PUBLIC  :: SLNK_CaseType
    LOGICAL :: IsInitialized = .false.
  ENDTYPE
  End Module
  program Ptest
  USE DerivedTypeMod, ONLY: SLNK_CaseType
  implicit none
  Type(SLNK_CaseType) :: SLNK_Case
  ! Body of Ptest
  print *, 'Start of Test'
  print *, SLNK_Case%IsInitialized
  print *, 'End of Test'
  end program Ptest
A__Valle
It works well when using the following, example, but the syntax error is returning if:
- Or Private in the DerivedTypeMod is uncommented
- Or the DerivedTypeMod is not fully used, but only the SL_CaseType from that mod.
Module BaseTypeMod
  Implicit None
  Private
    INTEGER :: CaseID
  ENDTYPE SL_CaseType
  End Module
  Implicit None
  !Private
  TYPE, PUBLIC, EXTENDS(SL_CaseType) :: SLNK_CaseType
  ENDTYPE
  End Module
  program Ptest
  USE DerivedTypeMod
!  USE DerivedTypeMod, ONLY: SLNK_CaseType
  implicit none
  end program Ptest
Thanks - I can reproduce this. Escalated as issue DPD200361156. I note that it works in 14.0 - probably related to improvements we tried to make in extended type debugging.
We've fixed this - I am hoping to see the fix in Update 1.
