29578 Discussions
dynamic allocated arrays as subroutine arguments
mcalindan
I recentlyexperimented memory corruption problems when passing dynamic allocate arrays to subroutines which expected static allocated ones. Icould not reproducethem on small examples but I am posting asmall program with such an approach. Do you see anypotential harmful code bellow, regarding the call to test_dyn subroutine?
Calin
! test_dyn_alloc.f90
program test_dyn_alloc
implicit none
real, allocatable :: mat(:,:)
integer mydim,i
mydim = 100
allocate(mat(mydim,mydim))
do i=1,mydim
call test_dyn(mydim,mat(1,i))
enddo
end program test_dyn_alloc
subroutine test_dyn(size,vect)
implicit none
integer size,i
real vect(1)
do i=1,size
vect(i)=i
enddo
end subroutine test_dyn
I'm not sure what you mean by "expected static". There's no problem with what you've done here - an allocatable array is usable just like any other array variable. The only thing that can get you into trouble is if the called routine accepts the array as assumed shape with DIMENSION(:) and you don't have an explicit interface. That can happen for any kind of array argument.
The only gripe I have with your code is that you declare the dummy argument to be dimension (1) instead of (*).
mcalindan
Thanks Steve.
