edit box visability
gfr1
How can I make an edit box visible during run time if the attribute on the properties is not checked
Jugoslav_Dujic
Valued Contributor II
USE DFWIN
iSt=ShowWindow(GetDlgItem(Dlg%hWnd, IDC_EDIT1), SW_SHOW or SW_HIDE)
Note that this will work only from callback routines (since Dlg%hWnd is not created before DlgModal). You might want to check DLG_VISIBLE extension in my XFLOGM.
Jugoslav
