29236 Discussions
embedding Access Sequel Server calls into Intel Visual FORTRAN XE
Dave_A__from_Lifeboa
Customer asks:
Do you or one of your group know of a product that will allow embedding Access Sequel Server calls into Intel Visual FORTRAN XE. The resulting program will be running in a Windows 32 bit server environment.
Can you help?
Thanks in advance.....Dave A. from Lifeboat.
Dave,
There are several options for this:
ForDBC - a commercial product
flibs/odbc - a library for doing ODBC calls from Fortran
f90SQL - A freeware version of a no-longer-supported product
COM access using the Fortran Module Wizard
Other users might add some more choices.
Arjen_Markus
As I have written the above flibs/odbc library, should you have any questions, let me know and I will
see that Ican answer them. I have to admit I have never used it in the context of Access SqlServer.
Arjen
