enforce implicit none
ggveldkamp2
I was wondering if there is a method of enforcing "implicit none" with some compiler option. I am already using /warn:declarations but I would like the compiler to stop with an error when an undeclared variable is encounterd.
Is there a compiler option to turn certain warnings into errors?
Guido
There is not at present an option to turn only selected warnings into errors. /warn:errors will turn ALL warnings into errors. However, the diagnostic you get with /warn:declarations is in fact an error severity and the behavior is the same as if you had said IMPLICIT NONE.
grg99
I think if you declare the routines in a module, and put "IMPLICIT NONE" at the head of the module, all the subroutines and function inherit the implicitaneousness. So that's one near-miss of a way of doing it. If I'm correct.
jimdempseyatthecove
In IVF 10.nn you have
/4{Y|N}d enable/disable default IMPLICIT NONE
Jim Dempsey
That's simply the Microsoft Fortran PowerStation spelling of /warn:declarations. It does the same thing.
ggveldkamp2
Hello Steve,
Do you know if an option to turn certain warnings into error is considered for a future version of the compiler?
Guido
jimdempseyatthecove
Guido,
As an interum measure you could write a script to scan the BuildLog for the warning messages and make it a post build process and/or Tool.
You could get fancy and make the application multiple projects, one being an empty main that calls the old main (program). Then make a verification project that scans the build log files and which builds a bogus subroutine.Structure it soverificatioin project will fail to build the bogus subroutine (deleting the old copy in the failure) and then the main will fail to link.
Jim Dempsey
I know we plan to offer finer-grained control over diagnostics. I don't recall if changing severity of specific diagnostics is part of the plan.
ggveldkamp2
Hello Jim,
We have a lot of (legacy) source code in many files for several programs. We use make as a build system. I have written a small tool to scan the source files and list all the functions and subroutines that don't have "implicit none". I have added "implicit none" to all our source now and I hoped I could prevent people from forgetting to add "implicit none" to new functions.
In my opinion implicit typing might be a good thing for the lazy programmer but if you are not very careful it will lead to bugs.
I also plan on using the /gen-interfaces option in the future to prevent even more bugs :-)
Guido
jimdempseyatthecove
Guido,
I too have been bitten by implicit many times over my 35 years of programming. Often it is due to a typographical error or ommission of inclusion of a header file or mod file.
I use TECO for making such global editing tasks.
Jim Dempsey
Guido,
If you want to enforce IMPLICIT NONE for all compiles on your system, edit the file ifort.cfg, found in the compiler's BIN folder, and add:
/warn:declarations
If you just save the file in place, it will be used until you update the compiler. You can save a copy elsewhere and define the system environment variable IFORTCFG to have a value of the complete path to the configuration file.
ggveldkamp2
Hello Steve,
I already use /warn:declarations (from the makefile), the only thing is that it generates a warning and not an error (ivf 9.1).
Guido
I see you are correct - I thought it was an error but it is indeed a warning. You could also add /warn:error which will change all warnings to errors.
jimdempseyatthecove
Guido,
As a work around, add the compiler option /Qdiag-file:YourNameHere.diag
Then in your make file
grep explicit.type Debug*.diag>NoType.txt
This assumes you have GREP.
If NoType.txt is 0 bytes in size then no error. Using one ofthe script languages (AWK, PEARL, other, or roll your own) you can make a test of NoType.txt and if not 0 length your make file can delete the execuitable or perform other such action as you see fit (delete offending .obj file prior to link).
Jim
