error #10037 could not find 'link'
okbi_z_
Greeting's I use the fresh version "Intel® Parallel Studio XE 2017"
I get this error :" error #10037 could not find 'link' " when trying to compile f90 sources.
After research, I can not find a solution. Thank you for helping me.
mecej4
There are a number of different scenarios where this could have happened, so you would need to provide more details regarding how you attempted the compilation -- such as whether you used Visual Studio, a command window or some other tool, etc. However, I note that you may have found the solution yourself since you posted another message (19 minutes later) in which you state that you were able to produce and run the EXE.
okbi_z_
Sorry, yes i use VS 2015, and no : i do not have found solution...
Thank's
Kevin_D_Intel
Check that you have the "Common Tools for Visual C++ 2015" components installed. See https://software.intel.com/en-us/articles/installing-visual-studio-2015-for-use-with-intel-compilers
