29386 Discussions
error #10040 of compiling the fortran under VS 2008
lucky_xrg
i have already installed the Intel Visual Fortran Compiler for Windows (w_cprof_p_11.1.060_novsshell.exe) under visual studio 2008. when i compile a simple fortran program, there are below errors appeared. so would you tell me how to solve the problem? thank you very much!
Build Log
Build started: Project: Console1, Configuration: Debug|Win32
Output
Compiling with Intel Visual Fortran 11.1.060 [IA-32]...
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug\\\\" /object:"Debug\\\\" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc8 /Qlocation,link,"C:\\Program Files\\Microsoft Visual Studio 8\\VC\\bin" "C:\\Projects\\Console1\\Console1\\Source1.f90"
ifort: error #10040: can't run 'C:\\PROGRA~1\\Intel\\Compiler\\11.1\\060\\bin\\ia32\\fortcom'; inaccessible drive or directory in PATH
ifort: error #10273: Fatal error in C:\\PROGRA~1\\Intel\\Compiler\\11.1\\060\\bin\\ia32\\fortcom, terminated by 0xffffffff
Console1 - 2 error(s), 0 warning(s)
TimP
You say you are compiling under VS2008, but you show a VS2005 setup. If you are running VS2005 under Vista or Windows 7, you must start it by run as administrator. Is the fortcom installed in that folder (as it should be)?
lucky_xrg
thanks for your reply. i guess you are good masteroncompilingVSs.i have the VS 2005 and 2008 both.And nextis the sameerror listjust as under VS 2005 for mypoint. my computer system is Windows XP. could you tell me how solve the problem?
And in the C:\Program Files\Intel\Compiler\11.1\060\bin\ia32 i have already installed fortcom.exe(18.3 MB). i don't know the reason. Waiting your next reply! thank you again!
Build Log
Build started: Project: FortranConsole1, Configuration: Debug|Win32
Output
ifort /nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug\" /object:"Debug\" /traceback /check:bounds /libs:static /threads /dbglibs /c /Qvc9 /Qlocation,link,"c:\Program Files\Microsoft Visual Studio 9.0\VC\bin" "C:\Xu-r\My Documents\Visual Studio 2008\Projects\FortranConsole1\FortranConsole1\three common programming traps.f90"
ifort: error #10040: can't run 'C:\PROGRA~1\Intel\Compiler\11.1\060\bin\ia32\fortcom'; inaccessible drive or directory in PATH
ifort: error #10273: Fatal error in C:\PROGRA~1\Intel\Compiler\11.1\060\bin\ia32\fortcom, terminated by 0xffffffff
FortranConsole1 - 2 error(s), 0 warning(s)
