29651 Discussions
error #5078: Unrecognized token ' ?' skipped
milenko1976
I have taken one function from press numerical recipees and...
milenko@milenkons:~/pauel$ ifort -c assert_eq.f90
assert_eq.f90(10): error #5078: Unrecognized token ' ?' skipped
write (*,*) nrerror: an assert_eq failed
assert_eq.f90(10): error #5078: Unrecognized token '?' skipped
assert_eq.f90(10): error #5078: Unrecognized token 'failed?' skipped
assert_eq.f90(10): error #5082: Syntax error, found ':' when expecting one of: , ;
assert_eq.f90(11): error #5078: Unrecognized token ' ?' skipped
STOP program terminated by assert_eq3
assert_eq.f90(11): error #5078: Unrecognized token '?' skipped
MODULE ASSERT_EQ
CONTAINS
FUNCTION assert_eq3(n1,n2,n3,string)
CHARACTER(LEN=*), INTENT(IN) :: string
INTEGER, INTENT(IN) :: n1,n2,n3
INTEGER :: assert_eq3
if (n1 == n2 .and. n2 == n3) then
assert_eq3=n1
else
end if
END FUNCTION assert_eq3
END MODULE
IanH
When you copied and pasted the code you brought over a character (a fancy single quote) that isn't in the set of characters that the intel compiler recognises. Have a close look at the single quote character that most of the error messages point to and compare it to the character that appears when you press the single quote key.
You need to replace this fancy quote character (and maybe others) with the quote character that is usually generated when you hit the corresponding key on your keyboard.
milenko1976
Thanks Ian,I will try it now.
jimdempseyatthecove
Ian, Milenko,
In Fortran, derived fromEnglish speaking world,both the single quote ' and single enquote ' are the same character (a vertical looking single upper "dit"). In other languages the single quote ` is a top side left leaning single upper "dit" mark, and single enquote (I don't have it on my keyboard) is a top side right leaning single upper "dit" mark.
If you captured this code using copy and paste through a text editor (which for some languagesnormally uses leaning single quotes) the text editor may have "done you a favor" by converting the quotes for you. In this case, it is not a favor at all.
Jim Dempsey
