29637 Discussions
error #5082: Syntax error, found '::' when expecting one of: (
lin_s_
I have a fortran program which contains several subroutines in seperate .for files. Right now I tried to transfer the fortran program into a dynamic link library.
I created a new dll, and define which subroutines can be called by external program. For one of the subroutines, when I add the sentence "!dec$ attributes dllexport::crsd04", and compile it, it showed the error "error #5082: Syntax error, found '::' when expecting one of: (" and "    Compilation Aborted (code 1)   "
The beginning of the program is as followed. In the following codes, there are "if..end if", "continue" and most are calculations. Thank you.
      subroutine crsd04(crskianrow0,crskianrow1,crsfae,crsrodf,crsxe135,
     &                  crssm149,crsrouc,crskiazoneij,crskcoeff,
     &                  crskcoeff1,crskcoeff2,crskrasig12,crskrasiga1,
     &                  crskrasiga2,crsdiff1,crsdiff2,crsnusigf1,
     &                  crsnusigf2,crssig12,crssiga1,crssiga2,crstf,
     &                  crskraxesiga1,crskraxesiga2,crskrasmsiga1,
     &                  crskrasmsiga2)
    implicit none
    integer*4 :: crskiny=13
    integer*4 :: crskinz=11
      integer*4 :: i,j,k
      real*8,DIMENSION(13) :: crskianrow0
      real*8,DIMENSION(13) :: crskianrow1
    real*8,DIMENSION(13,13,11) :: crsfae,crsrodf,crsxe135,crssm149
    real*8,DIMENSION(13,13,11) :: crsrouc
      integer*4,DIMENSION(13,13,11) :: crskiazoneij
      real*8,DIMENSION(9,7,3) :: crskcoeff
      real*8,DIMENSION(3,2,3) :: crskcoeff1,crskcoeff2
      real*8,DIMENSION(13,13,11) :: crskrasig12
      real*8,DIMENSION(13,13,11) :: crstf
      real*8,DIMENSION(13,13,11) :: crsdiff1,crsdiff2
      real*8,DIMENSION(13,13,11) :: crsnusigf1,crsnusigf2
      real*8,DIMENSION(13,13,11) :: crssig12,crsnusigf21,crskrasiga2
      real*8,DIMENSION(13,13,11) :: crssiga1,crssiga2,crskrasiga1
Steve_Lionel
Start the !DEC$ in column 1 (or 7). You have the ! in column 6 which makes it a continuation.
Steve_Lionel
lin_s_
Thank you Steve, it works right now!
