error #5082: Syntax error, found
David_H_10
Hi Steve
could you help me please?
David
I have following error:
Error    1     error #5082: Syntax error, found '(' when expecting one of: <END-OF-STATEMENT> ; <LABEL> BLOCK BLOCKDATA PROGRAM MODULE TYPE COMPLEX BYTE ...    c:\Source\neu29.05.15\src\traeger12\traeger12\traeger12\h_anstell.f90    13
here my cods:
 subroutine h_anstell (kontur, anstmass)
 use modmpc, only: profil
 record / profil/      kontur
 real(kind=8)     ::   anstmass
 integer          ::   i
 do i=1,kontur.anz_punkte
       if (kontur.pkt(i).y < 0 ) then
             (kontur.pkt(i).y = kontur.pkt(i).y - anstmass/2_8)
                elseif (kontur.pkt(i).y > 0) then
             (kontur.pkt(i).y = kontur.pkt(i).y + anstmass/2_8)
       endif
 enddo
 end subroutine
David_H_10
thanks
but I have found the error.
The clamp must move away
so below is correct and works
 integer          ::   i
       endif
 enddo
 end subroutine
