29383 Discussions
error #5149: Illegal character in statement label field
Ancy_T_
When I try to compile the program using ifort compilers, following error message is shown:
byte_order is LITTLE_ENDIAN
/opt/intel/bin/ifort -c  -O3 bfrini.f
bufrlib.prm(1): error #5149: Illegal character in statement label field  [/]
/* Copyright (C) 1991-2012 Free Software Foundation, Inc.
  • /* Copyright (C) 1991-2012 Free Software Foundation, Inc.
    bufrlib.prm(1): error #5118: First statement in file must not be continued
    bufrlib.prm(2): error #5149: Illegal character in statement label field
       This file is part of the GNU C Library.
    bufrlib.prm(4): error #5149: Illegal character in statement label field
       The GNU C Library is free software; you can redistribute it and/or
    bufrlib.prm(1): error #5082: Syntax error, found INTEGER_CONSTANT '1991' when expecting one of: => = . [ % (
    bufrlib.prm(5): error #5149: Illegal character in statement label field
       modify it under the terms of the GNU Lesser General Public
    bufrlib.prm(6): error #5149: Illegal character in statement label field
       License as published by the Free Software Foundation; either
    bufrlib.prm(4): error #5082: Syntax error, found '/' when expecting one of: => = . [ % ( :
    bufrlib.prm(7): error #5149: Illegal character in statement label field
       version 2.1 of the License, or (at your option) any later version.
    bufrlib.prm(9): error #5149: Illegal character in statement label field
       The GNU C Library is distributed in the hope that it will be useful,
    bufrlib.prm(10): error #5149: Illegal character in statement label field
       but WITHOUT ANY WARRANTY; without even the implied warranty of
    bufrlib.prm(7): error #5082: Syntax error, found INTEGER_CONSTANT '1' when expecting one of: <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT>
    bufrlib.prm(11): error #5149: Illegal character in statement label field
       MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    bufrlib.prm(12): error #5149: Illegal character in statement label field
       Lesser General Public License for more details.
    bufrlib.prm(14): error #5149: Illegal character in statement label field
       You should have received a copy of the GNU Lesser General Public
    bufrlib.prm(15): error #5149: Illegal character in statement label field
       License along with the GNU C Library; if not, see
    bfrini.f(76): catastrophic error: Too many errors, exiting
    compilation aborted for bfrini.f (code 1)
    make: *** [../../libbufr_v10.2.5_4_64.a(bfrini.o)] Error 1
    The system configuration used is :
    Architecture:          x86_64
    CPU op-mode(s):        32-bit, 64-bit
    Byte Order:            Little Endian
    CPU(s):                4
    On-line CPU(s) list:   0-3
    Thread(s) per core:    1
    Core(s) per socket:    4
    Socket(s):             1
    NUMA node(s):          1
    Vendor ID:             GenuineIntel
    CPU family:            6
    Model:                 63
    Model name:            Intel(R) Xeon(R) CPU E5-2640 v3 @ 2.60GHz
    OS: CentOS
    The same programs worked fine with the same compilers and flags, on Bosslinux and other CentOS systems.
    Please check and let me know ..how to fix the issue.
    Ancy
    Kevin_D_Intel
    The .f source file extension causes the compiler to treat the source file as containing fixed-format source. The source line that is flagged in error does not represent a valid Fortran comment statement. It appears to be a C/C++ style comment.
    You should to inspect the .f source file to see whether an incorrect (C/C++) file was included perhaps via an INCLUDE statement. If there is an INCLUDE statement then make certain the named file contains valid Fortran statements.
    TimP
    If your file was named with .F on linux, that would invoke pre-processing; the equivalent would occur with ifort  if you add -fpp option (or, on linux, if you retained the .F).
    mecej4
    I wonder if your include file buflib.prm has become corrupted. Instead of fixed format Fortran code + comments, it seems to contain C style comments -- in fact, I recognize pieces of the GNU copyleft notice.
    You may also see if the source file and the include file have consistent line endings, and are free of BOM marks and free of tabs.
    In general, INCLUDE '<filename>' directives and C style preprocessor directives and macros, #include, #ifdef, etc.) will not work well when both types of inclusion are used in a single file given to the compiler. In many compilers, a separate C-preprocessor pass takes care of the #include-s, and an internal pass of the Fortran compiler takes care of the INCLUDE "statements". What the Fortran compiler sees in its first pass can, thus, be quite different from what the programmer expects.
