29487 Discussions
error #5149: Illegal character in statement label field
htkang
Why I have these errors?
Almost all lines in the programare generate errors.
My Complier: Intel visual fortran 11.1 professional, 64 bit
My system: Window XP 64bit
*********************Error Messages***************************************************
: error #5149: Illegal character in statement label field
: error #5118: First statement in file must not be continued
mean.for<7>: error #5149:Illegal character in statement label field
---IMPLICT NONE
*********************Fortran Example Code*************************************************
! This program contains one subroutine for computing the
! arithmetic, geometric and harmonic means of three REALs.
PROGRAM Mean6
IMPLICIT NONE
REAL :: u, v, w
REAL :: ArithMean, GeoMean, HarmMean
READ(*,*) u, v, w
CALL Means(u, v, w, ArithMean, GeoMean, HarmMean)
WRITE(*,*) "Arithmetic Mean = ", ArithMean
WRITE(*,*) "Geometric Mean = ", GeoMean
WRITE(*,*) "Harmonic Mean = ", HarmMean
CONTAINS
! SUBROUTINE Means():
! This subroutine receives three REAL values and computes
! their arithmetic, geometric, and harmonic means.
SUBROUTINE Means(a, b, c, Am, Gm, Hm)
IMPLICIT NONE
REAL, INTENT(IN) :: a, b, c
REAL, INTENT(OUT) :: Am, Gm, Hm
Am = (a + b + c)/3.0
Gm = (a * b * c)**(1.0/3.0)
Hm = 3.0/(1.0/a + 1.0/b + 1.0/c)
END SUBROUTINE Means
END PROGRAM Mean6
TimP
Apparently, you have attempted to process current standard free form format as f77 fixed form. You can set the free form option, or engage it by default by naming your file with .f90 suffix.
IanH
The compiler looks at the extension on the source file (.for) and then thinks that the file is in fixed source form (column 1 for comment indicator, columns 2:5 for statement labels, column six for continuation, statements start in column seven, etc). I believe this source form was first developed by the ancient Sumerians in order to allow Fortran source to be recorded in cuneiform script (though originally limited to uppercase cuneiform only) on stone tablets.
The file is most likely in what is known as free source form. Try again after changing the file extension to ".f90" and see what happens.
Have a look in the index for the help for the compiler under "Source forms" and also at the help for the associated compiler options /free and /fixed for more information.
TimP
htkang
Quoting - IanH
THANK YOU.
htkang
Quoting - tim18
THANK YOU.
