I get the following compilation error on Lines 962, 997 and 1009 of SUBROUTINE HYBFHT (copy below):
error #6637: This actual argument must be the name of an external user function or the name of an intrinsic function. [FUN1]
Each of these lines is of the form:
CALL BESQUX(A,B,TERMR,TERMI,NG,NW,ORDER,R,FUN1,REL1,
1 FWORK,MAXREL)
But as far as I can see I have declared FUN1 both in the calling routine (HYBFHT) and the routine being called (BESQUX).
The declaration in both cases is:
EXTERNAL COMPLEX FUN1
Any suggestions would be most appreciated.
Leigh
SUBROUTINE HYBFHT(B,NB,NREL,TOL,NTOL,RERR,AERR,NORD,FUN1,REL1, * ZWORK,FWORK,BWORK,NPCS, IPATH,MAXDIM,MAXREL, ZANS,NFUN1,IERR) C======================================================================= C BY W.L.ANDERSON, U.S.GEOLOGICAL SURVEY, DENVER, COLORADO, USA. C======================================================================= C C HYBFHT - A HYBRID FAST HANKEL TRANSFORM SUBPROGRAM FOR RAPID AND C ACCURATE EVALUATION OF HANKEL TRANSFORMS OF ORDERS 0 AND/OR 1. C SUB-METHODS WITHIN HYBFHT ARE RELATED OR LAGGED CONVOLUTIONS USING C ANDERSON'S (1982) DIGITAL FILTERING SUBPROGRAM (HANKL), AND/OR C CHAVE'S (1983) DIRECT QUADRATURE SUBPROGRAM (BESAUX), WHERE THE C COMPLEX KERNEL FUNCTIONS CAN BE HIGHLY OSCILLATORY AS WELL AS C DECREASING, INCREASING, OR OF BOUNDED VARIATION. C C SUBPROGRAM HYBFHT HAS SEVERAL OPTIONS THAT THE USER MAY SELECT C TO CONTROL HOW THE ALGORITHM PERFORMS IN SPEED AND/OR ACCURACY C (SEE DEFINITION OF PARAMETER IPATH). THE IDEA WAS TO USE TWO C DIFFERENT ALGORITHMS IN SUCH A WAY AS TO TAKE ADVANTAGE OF THE C BEST FEATURES OF EACH ALGORITHM FOR TOTAL PERFORMANCE, AND TO C SOLVE A WIDER CLASS OF PROBLEMS INVOLVING HANKEL TRANSFORMS. C C NOTE THAT THE ORIGINAL SUB-METHOD SUBPROGRAMS HAVE BEEN RENAMED C AND SOMEWHAT MODIFIED TO COEXIST UNDER CONTROL OF HYBFHT IN C SINGLE-PRECISION COMPLEX ARITHMETIC. (A DOUBLE-PRECISION VERSION C USING COMPLEX*16, CALLED HY2FHT, IS ALSO AVAILABLE.) C C======================================================================= C C REFERENCES: C C ANDERSON, W.L., 1982, FAST HANKEL TRANSFORMS USING RELATED AND LAGGED C CONVOLUTIONS: ACM TRANS. ON MATH. SOFTWARE, VOL.8, NO.4, P.344-368. C C --------, 1984, DISCUSSION ON: "NUMERICAL INTEGRATION OF RELATED C HANKEL TRANSFORMS BY QUADRATURE AND CONTINUED FRACTION EXPANSION" C (BY A.D. CHAVE), WITH REPLY BY AUTHOR: GEOPHYSICS, VOL.49, NO.10, C P.1811-1813. C C CHAVE, A.D., 1983, NUMERICAL INTEGRATION OF RELATED HANKEL TRANSFORMS C BY QUADRATURE AND CONTINUED FRACTION EXPANSION: GEOPHYSICS, VOL.48, C NO.12, P.1671-1686. C C======================================================================= C C INPUT PARAMETERS: C C B() - (REAL) ARRAY OF HANKEL TRANSFORM ARGUMENTS B(I), I=1,..,NB. C FOR ONLY A SINGLE ARGUMENT B(1), USE NB=1; NB>1 IMPLIES C SUBROUTINES HANKL AND/OR BESAUX TO BE INVOKED AS REQUIRED C USING THE SPECIFIC B-ARGUMENTS AS LISTED IN THE INPUT ARRAY C B(I), WHERE B(I)>B(I-1)>0.0 FOR ALL I=2,...,NB. NOTE THAT C NB>1 OPTION IS FURTHER CONTROLLED BY PARAMETER IPATH BELOW. C B() IS ASSUMED DIMENSIONED B(MAXDIM), WHERE MAXDIM IS C DEFINED IN HYBFHT AS AN ADJUSTABLE DIMENSION. WHEN HANKL C IS USED (IPATH=+-1), ARRAY B() IS USED TO INTERPOLATE C A CUBIC SPLINE AFTER LAGGED CONVOLUTIONS ARE PERFORMED; C WHEN BESAUX IS USED (IPATH=+-2), EACH B() IS USED DIRECTLY C TO OBTAIN RESULTS VIA A SEPARATE CALL TO BESAUX. C NB - (INTEGER) NUMBER OF B'S GIVEN IN ARRAY B(I), I=1,NB>=1. C NOTE THAT NB IS THE EXACT NUMBER OF INCREASING ARGUMENTS, C AND IS NOT THE NUMBER OF LAGGED CONVOLUTIONS (MB) AS C DEFINED IN SUBROUTINE HANKL. IN GENERAL, 1<=NB<=NREL<=MAXREL IS REQUIRED (SEE MAXREL BELOW). C TOL - (REAL) TOLERANCE FACTOR PASSED TO SUBROUTINE HANKL, AS C REQUIRED, DEPENDING ON PARAMETER IPATH SELECTED. NORMALLY, C TOL=.1E-8 IS THE SUGGESTED TOLERANCE THAT SHOULD BE USED TO C YIELD THE APPROXIMATE RELATIVE ERROR (.1E-6) FROM HANKL C USING 32-BIT FLOATING-POINT WORDS IN SINGLE-PRECISION. C TOL=0.0 CAN BE SET FOR THE MAXIMUM ACCURACY POSSIBLE. C (SEE MORE INFORMATION ON "TOL" IN SUBROUTINE HANKL.) C NTOL - (INTEGER) NUMBER OF CONSECUTIVE TIMES THE TOLERANCE IS MET C IN SUBROUTINE HANKL, AS REQUIRED, DEPENDING ON PARAMETER C IPATH SELECTED. NORMALLY, FOR SMOOTH NON-OSCILLATORY C KERNELS, NTOL=1 IS SUFFICIENT, AND NTOL=2 OR 3 POSSIBLY FOR C OSCILLATING KERNELS TO AVOID A PREMATURE CUT-OFF OF THE C ADAPTIVE CONVOLUTION ALGORITHM IN HANKL. C (SEE MORE INFORMATION ON "NTOL" IN SUBROUTINE HANKL.) C RERR - (REAL) REQUESTED RELATIVE ERROR PASSED TO SUBROUTINE BESAUX C AS REQUIRED, DEPENDING ON PARAMETER IPATH SELECTED. RERR C SHOULD NOT BE CHOSEN MUCH SMALLER THAN ABOUT .1E-6 BECAUSE C THIS IS A 32-BIT FLOATING-POINT COMPLEX VERSION OF BESAUX C TO COEXIST WITH HANKL IN SINGLE-PRECISION COMPLEX. C (SEE MORE INFORMATION ON "RERR" IN SUBROUTINE BESAUX.) C AERR - (REAL) REQUESTED ABSOLUTE ERROR PASSED TO SUBROUTINE BESAUX C AS REQUIRED, DEPENDING ON PARAMETER IPATH SELECTED. AERR C SHOULD NOT BE CHOSEN TOO CLOSE TO ZERO, BUT THIS DEPENDS C ON THE PARTICULAR "FUN1" AND/OR "REL1" BEING USED. A GOOD C RULE OF THUMB IS TO GENERALLY CHOOSE AERR<=1.E-2*RERR. C (SEE MORE INFORMATION ON "AERR" IN SUBROUTINE BESAUX, AND C ALSO IN CHAVE, 1983, P.1673.) C NORD() - (INTEGER) ARRAY OF HANKEL TRANSFORM ORDERS NORD(I), I=1, C NREL>=1. NOTE THAT NORD(I)=0 OR 1 IS ALWAYS REQUIRED FOR C I=1,NREL. ONLY ORDERS 0 OR 1 MAY BE USED IN HYBFHT, IN ANY C COMBINATION; HOWEVER, NOT ALL NREL TRANSFORMS CAN BE FOUND C AS RELATED TRANSFORMS IF ORDERS ARE UNEQUAL AND WHEN IPATH C IS SELECTED SUCH THAT SUBROUTINE BESAUX IS CALLED. THIS C IS NOT THE CASE IF SUBROUTINE HANKL IS CALLED, SINCE THE C DIGITAL FILTERS CAN OBTAIN RELATED TRANSFORMS OF EITHER C ORDERS 0 OR 1 IN ANY NORD() SEQUENCE DESIRED. C NORD() IS ASSUMED DIMENSIONED NORD(MAXREL), WHERE MAXREL C IS DEFINED IN HYBFHT AS AN ADJUSTABLE DIMENSION. C FUN1 - NAME OF AN EXTERNAL DECLARED COMPLEX FUNCTION WRITTEN BY C THE USER TO EVALUATE FUN1(X) FOR X>0.0. AN EXTERNAL C STATEMENT MUST APPEAR IN THE USER'S CALLING PROGRAM AS: C EXTERNAL FUN1 C AND THE COMPLEX FUNCTION MUST HAVE THE GENERAL FORM: C (REPLACE "<...>" BELOW AS REQUIRED.) C C COMPLEX FUNCTION FUN1(X) C COMMON/PASS/<...INCLUDE PARAMETERS AS NEEDED...> C <...> C FUN1=CMPLX(<...>,<...>) C RETURN C END C C NOTES: IF PARAMETERS ARE NEEDED IN FUN1 (FOR EXAMPLE A,C), C THEN USE "COMMON/PASS/A,C" IN CALLING PROGRAM AND FUN1. C FUN1 MAY BE OSCILLATING, INCREASING, DECREASING, OR OF C BOUNDED VARIATION AS THE ARGUMENT X>0 INCREASES. (SEE MORE C INFORMATION ON "FUN1" IN SUBROUTINES HANKL AND BESAUX.) C REL1 - NAME OF AN EXTERNAL DECLARED SUBROUTINE WRITTEN BY THE USER C TO EVALUATE ANY (AND ALL) NREL RELATED KERNELS FJ(NREL) C AS A FUNCTION OF F1=FUN1(X), ASSUMED PREVIOUSLY EVALUATED. C AN EXTERNAL STATEMENT MUST APPEAR IN THE USER'S PROGRAM AS: C EXTERNAL REL1 C AND THE SUBROUTINE MUST HAVE THE GENERAL FORM: C (REPLACE "<...>" BELOW AS REQUIRED.) C C SUBROUTINE REL1(X,F1,FJ,J) C COMPLEX F1,FJ(1) C COMMON/PASS/<...INCLUDE PARAMETERS AS NEEDED...> C IF(J.LT.0) GO TO (1,2,<...UP TO NREL...>), IABS(J) C 1 FJ(1)=F1 C IF(J.LT.0) RETURN C 2 FJ(2)= <...EXPRESSION IN TERMS OF X,F1, ETC...> C IF(J.LT.0) RETURN C <...> C RETURN C END C C DEFINITION OF REL1(X,F1,FJ,J) PARAMETERS: C ---------------------------------------- C X = REAL INPUT VARIABLE (CONTROLLED BY HYBFHT). C F1 = COMPLEX INPUT FUNCTION FUN1(X) VALUE GIVEN BY HYBFHT. C FJ()= COMPLEX OUTPUT ARRAY OF RELATED KERNEL FUNCTIONS, WHICH C **** THE USER MUST CODE; NOTE THAT EACH FJ(J) MAY OR MAY NOT C BE A SIMPLE FUNCTION OF X, F1 AND/OR OTHER PARAMETERS AS C PASSED IN COMMON/PASS/ FROM THE USER'S CALLING PROGRAM. C J = INTEGER INPUT VARIABLE (CONTROLLED BY SUBROUTINE HYBFHT). C OPTION: WHEN J<0, THEN ONLY THE IABS(J) RELATED KERNEL C IS RETURNED IN FJ(IABS(J)); WHEN J>0, ALL RELATED KERNELS C FJ(I), I=1,J ARE RETURNED, WHERE FJ(1)=F1 ALWAYS REQUIRED. C (SEE REL1 EXAMPLE INCLUDED WITH THE TEST DRIVER OF HYBFHT) C ZWORK() - (COMPLEX) ARRAY OF DIMENSION ZWORK(283,MAXREL), WHERE C MAXREL IS DEFINED IN HYBFHT AS AN ADJUSTABLE DIMENSION. C ZWORK() IS ONLY USED BY SUBROUTINE HANKL, AS REQUIRED, C DEPENDING ON PARAMETER IPATH SELECTION. C FWORK() - (COMPLEX) ARRAY OF DIMENSION FWORK(MAXREL), WHERE C MAXREL IS DEFINED IN HYBFHT AS AN ADJUSTABLE DIMENSION. C FWORK() IS USED BY EITHER SUBROUTINES HANKL OR HYBFHT, C AS REQUIRED, DEPENDING ON PARAMETER IPATH SELECTION. C BWORK() - (REAL) ARRAY OF DIMENSION BWORK(MAXDIM,9), WHERE MAXDIM C IS DEFINED IN HYBFHT AS AN ADJUSTABLE DIMENSION. BWORK() C IS ONLY USED WHENEVER SUBROUTINE HANKL IS CALLED, AS C REQUIRED, DEPENDING ON PARAMETER IPATH SELECTION. C NPCS - (INTEGER) NUMBER OF PIECES FOR PARTIAL INTEGRATION AS C USED BY SUBROUTINE BESAUX, AS REQUIRED, DEPENDING ON C PARAMETER IPATH SELECTION. NORMALLY SET NPCS=1, BUT NPCS C CAN BE SET GREATER THAN 1 FOR DIFFICULT KERNELS. C (SEE MORE INFORMATION ON "NPCS" IN SUBROUTINE BESAUX.) C IPATH - (INTEGER) OPTION CONTROL PATH IN SUBROUTINE HYBFHT DEFINED C AS FOLLOWS: --------------------------------- C = 1 TO FORCE USE OF ONLY SUBROUTINE HANKL, AND AS CONTROLLED C BY INPUT PARAMETERS ABOVE RELATED TO SUBROUTINE HANKL. C = 2 TO FORCE USE OF ONLY SUBROUTINE BESAUX, AND AS CONTROLLED C BY INPUT PARAMETERS ABOVE RELATED TO SUBROUTINE BESAUX. C = -1 TO BEGIN WITH SUBROUTINE HANKL, BUT CHECK DURING ADAPTIVE C CONVOLUTION IF A HIGHLY OSCILLATORY KERNEL IS BEING USED C SUCH THAT THE OSCILLATIONS EXCEED THE FILTER'S NYQUIST C FREQUENCY AS TRANSFORMED TO LOG-SPACE, I.E., 1/(2*0.2). C IF THIS OCCURS, THEN HYBFHT WILL AUTOMATICALLY ABORT HANKL C AND SWITCH TO SUBROUTINE BESAUX. THE NUMBER OF FUNCTION C FUN1 EVALUATIONS WILL BE NOTED IN OUTPUT ARRAY NFUN1(1) FOR C HANKL (UNTIL ABORTED) AND NFUN1(2) AT EXIT. IF NFUN1(2)=0 C AT EXIT, THEN NO ABORT OCCURRED, AND SUBROUTINE HANKL WAS C ONLY USED. C = -2 PERFORM A RELATIVE ERROR CHECK USING BOTH SUBROUTINES HANKL C AND BESAUX AT THE END POINTS B(1) AND B(NB) ONLY WHEN C NB>2 IS SELECTED. THE ASSUMPTION IS THAT BESAUX IS MORE C ACCURATE, IN GENERAL, AND HENCE CAN BE USED TO DETERMINE C IF HANKL IS SUFFICIENTLY ACCURATE FOR LAGGED CONVOLUTION C TO BE PERFORMED FOR THE ENTIRE RANGE OF B(I),I=1,NB>2. C IF THE RELATIVE ERRORS AT B(1) OR B(NB) ARE LESS THAN OR C EQUAL TO PARAMETER RERR*10, THEN SUBROUTINE HANKL IS USED; C ELSE SUBROUTINE BESAUX IS USED. THE NUMBER OF FUNCTION C FUN1 EVALUATIONS WILL BE NOTED IN OUTPUT ARRAY NFUN1(1) C AND NFUN1(2), WHERE SOME EXTRA EVALUATIONS ARE SOMETIMES C NECESSARY TO PERFORM THE RELATIVE ERROR TESTS, AND WHEN C HANKL IS FOLLOWED TO COMPLETION. HOWEVER, IF NB>>2, C THEN MANY FUN1 EVALUATIONS ARE SAVED WITH HANKL THAN WITH C BESAUX DUE TO LAGGED CONVOLUTIONS. THUS IPATH=-2 IS SAFE C AND USUALLY NOT TIME-CONSUMING IN MOST CASES WHEN NB>>2. C (IF IPATH=-2 AND NB<=2, THEN ONLY BESAUX IS USED.) C MAXDIM - (INTEGER) MAXIMUM DIMENSION USED IN PROGRAM THAT CALLS C SUBROUTINE HYBFHT FOR ARRAYS: B(MAXDIM),BWORK(MAXDIM,9), C ZANS(MAXDIM,MAXREL). NB<=MAXDIM IS REQUIRED IF IPATH=+-2 C AND MB=AINT(5.*ALOG(B(NB)/B(1)))+5<=MAXDIM IF IPATH=+-1. C IT IS RECOMMENDED THE LATTER RELATION ALWAYS BE USED SUCH C THAT MAXDIM>>NB. (THIS WILL ALLOW FOR ANY IPATH OPTION.) C MAXREL - (INTEGER) MAXIMUM DIMENSION USED IN PROGRAM THAT CALLS C SUBROUTINE HYBFHT FOR ARRAYS: ZWORK(283,MAXREL), C ZANS(MAXDIM,MAXREL), AND FWORK(MAXREL). NOTE THAT C NREL<=MAXREL IS REQUIRED. C C----------------------------------------------------------------------- C C OUTPUT PARAMETERS: C C ZANS() - (COMPLEX) ARRAY OF HANKEL TRANSFORM RESULTS ZANS(I,J), C I=1,NB AND J=1,NREL. THE COMPLEX ARRAY IS ASSUMED TO BE C DIMENSIONED IN THE CALLING PROGRAM AS: ZANS(MAXDIM,MAXREL). C NOTE THAT 1<=NB<=MAXDIM AND 1<=NREL<=MAXREL ARE REQUIRED. C NFUN1() - (INTEGER) ARRAY OF NUMBER OF FUNCTION FUN1 EVALUATIONS C TAKEN BY EITHER SUBROUTINE HANKL (STORED IN NFUN1(1)) C AND/OR SUBROUTINE BESAUX (STORED IN NFUN1(2)). USUALLY, C NFUN1(1) IS NOT MUCH LARGER THAN THE NUMBER OF WEIGHTS C NEEDED FOR A SINGLE DIRECT CONVOLUTION (FOR ANY NB, NREL). C WITH REGARD TO IPATH SELECTED, NFUN1(2) IS GENERALLY LARGER C THAN NFUN1(1), BUT THIS DEPENDS ON PARAMETERS TOL, RERR, C AERR SELECTED. NOTE THAT NFUN1() REFLECTS THE OUTCOME OF C PARAMETER IPATH, AND AS A RESULT OF THE FUN1 AND REL1 C SUBPROGRAMS USED IN A CALL TO SUBROUTINE HYBFHT. C IERR - (INTEGER) ERROR RETURN CODE DEFINED AS FOLLOWS: C = 0 NO ERROR DETECTED IN INPUT PARAMETERS. C = 1 ERROR RETURN: NB<1 OR NB>MAXDIM NOT ALLOWED. C = 2 ERROR RETURN: NREL<1 OR NREL>MAXREL NOT ALLOWED. C = 3 ERROR RETURN: B(I-1)<=0 OR B(I)<=B(I-1), I=2,NB. C (ARRAY B(I)=0.0 OR NOT INCREASING FOR I=1,NB.) C = 4 ERROR IPATH=+-1: MB=AINT(5.*ALOG(B(NB)/B(1)))+5>MAXDIM. C (MB TOO LARGE, OR MAXDIM TOO SMALL HAS BEEN SELECTED.) C = 5 ERROR IPATH=+-1: SPLIN1 ERROR RETURN AFTER CALL SPLIN1. C (THIS SHOULD NEVER OCCUR IN PRACTICE DUE TO PRIOR CHECKS.) C = 6 ERROR RETURN: IPATH<-2, IPATH=0, OR IPATH>2 NOT ALLOWED. C = 11 ERROR IPATH=+-1 OR -2: ERROR RETURN AFTER CALL HANKL. C (SEE SUBROUTINE HANKL IERR=1 CAUSES AND CORRECTIVE ACTION.) C = 21 ERROR IPATH=2: ERROR RETURN AFTER CALL BESAUX. C (SEE SUBROUTINE BESAUX IERR=1 CAUSES; POSSIBLE CORRECTION C IS TO TRY USING NPCS>1 AND INCREASE RERR, AERR.) C = 31 ERROR IPATH=-1 OR -2: ERROR RETURN AFTER CALL BESAUX. C (SEE SUBROUTINE BESAUX IERR=1 CAUSES; POSSIBLE CORRECTION C IS TO TRY USING NPCS>1 AND INCREASE RERR, AERR.) C C======================================================================= C C HYBFHT USAGE: (REPLACE "<...>" BELOW AS REQUIRED.) C C THE USER'S PROGRAM SHOULD CONTAIN THE FOLLOWING STATEMENTS: C ---------------------------------------------------------- C C PARAMETER (MAXDIM= <...>,MAXREL= <...>) C INTEGER NORD(MAXREL),NFUN1(2) C REAL B(MAXDIM),BWORK(MAXDIM,9) C COMPLEX ZWORK(283,MAXREL),ZANS(MAXDIM,MAXREL),FWORK(MAXREL) C EXTERNAL FUN1,REL1 <,...POSSIBLY INCLUDE FUN2,REL2, ETC...> C COMMON/PASS/<...USE TO PASS OTHER PARAMETERS TO FUN1, ETC...> C <...> C CALL HYBFHT(<...SEE CALLING SEQUENCE ABOVE...>) C IF(IERR.NE.0) STOP <...> C <...> C END C COMPLEX FUNCTION FUN1(X) C <...SEE FORM OF FUN1 ABOVE...> C END C SUBROUTINE REL1(X,F1,FJ,J) C <...SEE FORM OF REL1 ABOVE...> C END C C======================================================================= C INTEGER NORD(MAXREL),NFUN1(2) REAL B(MAXDIM),BWORK(MAXDIM,9),DER(2) COMPLEX ZWORK(283,MAXREL),ZANS(MAXDIM,MAXREL),FWORK(MAXREL) DOUBLE PRECISION BESR,BESI EXTERNAL COMPLEX FUN1 !20090922 EXTERNAL REL1 COMMON/CONTRL/JPATH,J COMMON/TEST/NG,NF2,NI DATA DER/2*0.0/ C C PRESET AND TEST SOME PARAMETERS (OTHERS TESTED IN SUBR. CALLS) IERR=0 NFUN1(1)=0 NFUN1(2)=0 IF(NB.LT.1.OR.NB.GT.MAXDIM) THEN IERR=1 RETURN ELSE IF(NREL.LT.1.OR.NREL.GT.MAXREL) THEN IERR=2 RETURN ELSE IF(NB.GT.1) THEN DO 5 I=2,NB IF(B(I).LE.B(I-1).OR.B(I-1).LE.0.0) THEN IERR=3 RETURN ENDIF 5 CONTINUE ENDIF C PROCESS VIA IPATH SELECTION (SEE IPATH DEFINITIONS) JPATH=IPATH 10 KPATH=IABS(JPATH) C--BEGINNING OF "IF(KPATH.EQ.1) THEN" LOOP: IF(KPATH.EQ.1) THEN IF(NB.GT.1) THEN BMAX=B(NB) MB=AINT(5.*ALOG(BMAX/B(1)))+5 IF(MB.GT.MAXDIM) THEN IERR=4 RETURN ENDIF ELSE BMAX=B(1) MB=1 ENDIF C FHT FILTER METHOD (JPATH=-1 OR +1) C ********************************** CALL HANKL(BMAX,MB,NREL,TOL,NTOL,NORD,FUN1,REL1,ZWORK,FWORK, 1 MAXDIM,MAXREL, ZANS,BWORK(1,1),NF1,IER) NFUN1(1)=NFUN1(1)+NF1 IF(IER.NE.0) THEN IERR=IER+10 RETURN ENDIF C JPATH=-2 CAN BE SET AUTOMATICALLY BY HANKL IF IPATH=-1 WAS SET AND C POOR ACCURACY OBTAINED BY HANKL DUE TO HIGHLY OSCILLATING KERNELS. IF(JPATH.EQ.-2) THEN I1=1 INB=NB GO TO 110 ENDIF IF(NB.EQ.1) RETURN C NB>1, GET SPLINE INTERPOLATED ZANS(I,NREL) AT B(I),I=1,NB. DO 100 J=1,NREL K=8 DO 20 I=1,MB BWORK(I,8)=0.0 BWORK(I,9)=0.0 IF(J.EQ.1) BWORK(I,1)=ALOG(BWORK(I,1)) BWORK(I,2)=REAL(ZANS(I,J)) IF(AIMAG(ZANS(I,J)).NE.0.0) K=-8 20 CONTINUE 30 KK=IABS(K) CALL SPLIN1(MB,0.0,BWORK(1,1),BWORK(1,2),BWORK(1,3), 1 BWORK(1,4),BWORK(1,5),0,DER,BWORK(1,6),BWORK(1,7)) IF(MB.LT.0) THEN IERR=5 RETURN ENDIF DO 40 I=1,NB BLOG=ALOG(B(I)) IF(BLOG.LT.BWORK(1,1)) THEN BWORK(I,KK)=BWORK(I,2) ELSE IF(BLOG.GT.BWORK(MB,1)) THEN BWORK(I,KK)=BWORK(MB,2) ELSE CALL SPOINT(MB,BWORK(1,1),BWORK(1,2),BWORK(1,3), 1 BWORK(1,4),BWORK(1,5),BLOG,BWORK(I,KK)) ENDIF 40 CONTINUE IF(K.EQ.-8) THEN K=9 DO 50 I=1,MB BWORK(I,2)=AIMAG(ZANS(I,J)) 50 CONTINUE GO TO 30 ELSE DO 60 I=1,NB ZANS(I,J)=CMPLX(BWORK(I,8),BWORK(I,9)) 60 CONTINUE ENDIF 100 CONTINUE C DONE WITH SPLINE INTERPOLATION WHEN NB>1 AND NREL>=1. RETURN C--REST OF "IF(KPATH.EQ.1) THEN" LOOP ABOVE: ELSE IF(KPATH.EQ.2) THEN I1=1 INB=NB IF(IPATH.EQ.2.OR.NB.LT.3) GO TO 110 C SPECIAL PREPROCESSING ONLY WHEN IPATH=-2 AND NB>2 RERR10=10.*RERR DO 105 I=NB,1,1-NB CALL HANKL(B(I),1,NREL,TOL,NTOL,NORD,FUN1,REL1,ZWORK,FWORK, 1 MAXDIM,MAXREL, ZANS,BWORK(1,1),NF1,IER) NFUN1(1)=NFUN1(1)+NF1 IF(IER.NE.0) THEN IERR=IER+10 RETURN ENDIF DO 105 J=1,NREL IF(J.GT.1.AND.NORD(J).EQ.NORD(1)) THEN NEW=2 CALL RELATE(FWORK,MAXREL,REL1,J,0) ELSE IF(NREL.GT.1) THEN NEW=1 ELSE NEW=0 ENDIF ENDIF TESTR=REAL(ZANS(1,J)) TESTI=AIMAG(ZANS(1,J)) C GET ASSUMED TRUE VALUES FROM BESAUX AT THIS (I,J),I=NB OR 1, J=1,NREL C AND COMPARE WITH HANKL TEST VALUES AT THE END POINTS B(NB), B(1). C SWITCH TO IPATH=1 OR 2 DEPENDING ON RELATIVE ERROR TESTS. CALL BESAUX(BESR,BESI,DFLOAT(NORD(J)),1,7,DBLE(B(I)),FUN1, 1 REL1, FWORK,MAXREL,DBLE(RERR),DBLE(AERR),NPCS,NEW,IER) NFUN1(2)=NFUN1(2)+NF2 IF(IER.NE.0) THEN IERR=IER+30 C RETURNS WITH IERR=31 ENDIF ZANS(I,J)=CMPLX(SNGL(BESR),SNGL(BESI)) IF(J.EQ.1.AND.NREL.GT.1) CALL RELATE(FWORK,MAXREL,REL1,J,1) TRUE=SNGL(BESR) IF(TRUE.NE.0.0) THEN RELERR=ABS((TESTR-TRUE)/TRUE) IF(RELERR.GT.RERR10) THEN IF(I.EQ.NB) THEN INB=NB-1 ELSE IF(I.EQ.1) THEN I1=2 INB=NB-1 ENDIF JPATH=2 IF(J.EQ.NREL) GO TO 110 ENDIF ENDIF TRUE=SNGL(BESI) IF(TRUE.NE.0.0) THEN RELERR=ABS((TESTI-TRUE)/TRUE) IF(RELERR.GT.RERR10) THEN IF(I.EQ.NB) THEN INB=NB-1 ELSE IF(I.EQ.1) THEN I1=2 INB=NB-1 ENDIF JPATH=2 IF(J.EQ.NREL) GO TO 110 ENDIF ENDIF 105 CONTINUE JPATH=1 GO TO 10 C--REST OF "IF(KPATH.EQ.1) THEN" LOOP ABOVE: ELSE IERR=6 RETURN ENDIF C QUADRATURE METHOD (JPATH=-2 OR +2) C ********************************** 110 DO 200 I=I1,INB DO 200 J=1,NREL IF(J.GT.1.AND.NORD(J).EQ.NORD(1)) THEN NEW=2 CALL RELATE(FWORK,MAXREL,REL1,J,0) ELSE IF(NREL.GT.1) THEN NEW=1 ELSE NEW=0 ENDIF ENDIF CALL BESAUX(BESR,BESI,DFLOAT(NORD(J)),1,7,DBLE(B(I)),FUN1, 1 REL1, FWORK,MAXREL,DBLE(RERR),DBLE(AERR),NPCS,NEW,IER) NFUN1(2)=NFUN1(2)+NF2 IF(IER.NE.0) THEN IF(JPATH.EQ.-2) THEN IERR=IER+30 ELSE IERR=IER+20 ENDIF C RETURNS WITH IERR>=21 ENDIF ZANS(I,J)=CMPLX(SNGL(BESR),SNGL(BESI)) IF(J.EQ.1.AND.NREL.GT.1) CALL RELATE(FWORK,MAXREL,REL1,J,1) 200 CONTINUE RETURN END SUBROUTINE RELATE(FWORK,MAXREL,REL1,JREL,ISAVE) C---------------------------------------------------------------------- C GET RELATED KERNELS AS REQUIRED FOR SUBROUTINE BESAUX VIA CALL REL1. C NOTE ALL I/O PARAMETERS CONTROLLED BY HYBFHT. THE USER ONLY NEEDS C TO CODE EXTERNAL SUBROUTINE REL1 TO COMPUTE ANY (OR ALL) RELATED C KERNELS. (SEE COMMENTS ABOUT SUBROUTINE REL1 IN HYBFHT.) C---------------------------------------------------------------------- IMPLICIT DOUBLE PRECISION (A-H,K,O-Z) C NTERM IS MAXIMUM NUMBER OF BESSEL FUNCTION LOOPS STORED IF NEW.NE.0 PARAMETER (NTERM=50) SAVE KSAVE,KASAVE,KBSAVE,NKSAVE,NPSAVE,NPSAV REAL X,FRE,FIM DIMENSION KARG(255,NTERM),KERN(510,NTERM),NK(NTERM), 1 KBES(510,NTERM),KSAVE(510,NTERM),KASAVE(255,NTERM), 2 KBSAVE(510,NTERM),NKSAVE(NTERM) COMPLEX FWORK(MAXREL) EXTERNAL REL1 COMMON/BESINT/NK,NP,NPS,KARG,KERN,KBES IF(ISAVE.EQ.1) THEN NPSAV=NP NPSAVE=NPS DO 1 I=1,MIN(NPS,100) NKSAVE(I)=NK(I) 1 CONTINUE ELSE NP=NPSAV NPS=NPSAVE DO 2 I=1,MIN(NPS,100) NK(I)=NKSAVE(I) 2 CONTINUE ENDIF C DO 10 I=1,MIN(NPS,100) LK=1 DO 10 J=1,2**(NK(I)+1)-1 IF(ISAVE.EQ.1) THEN TBES=KBES(J,I) IF(TBES.NE.0.0) THEN RBES=1.0/TBES ELSE RBES=0.0 ENDIF KSAVE(LK,I)=KERN(LK,I)*RBES KSAVE(LK+1,I)=KERN(LK+1,I)*RBES KASAVE(J,I)=KARG(J,I) KBSAVE(J,I)=KBES(J,I) LK=LK+2 GO TO 10 ENDIF C--GET SAVED ARGUMENT, BESSEL, AND KERNEL FUNCTION VALUE FOR F1. X=KASAVE(J,I) TBES=KBSAVE(J,I) FRE=KSAVE(LK,I) FIM=KSAVE(LK+1,I) C--GET RELATED KERNEL FROM SAVED KERNEL AS REQUIRED VIA CALL REL1. CALL REL1(X,CMPLX(FRE,FIM),FWORK,-JREL) KERN(LK,I)=REAL(FWORK(JREL))*TBES KERN(LK+1,I)=AIMAG(FWORK(JREL))*TBES LK=LK+2 10 CONTINUE RETURN END SUBROUTINE SPLIN1(M,H,X,Y,A,B,C,IT,D,P,S) C--ONE DIMENSIONAL CUBIC SPLINE COEFFICIENT DETERMINATION. C C BY W.L.ANDERSON, U.S. GEOLOGICAL SURVEY, DENVER, COLORADO C C PARMS--- M= NUMBER OF DATA POINTS .GT. 2 C H= EQUAL INTERVAL OPTION WHEN H.GT.0. (USE DUMMY X HERE), C UNEQUAL INTERVALS IF H=0. (X REQUIRED STORAGE) C X= INDEP.VAR WHEN H=0. (DIM .GE. M). C Y= DEPENDENT VARIABLE (DIM .GE. M). C A,B,C=COEFF.ARRAYS (EACH DIM .GE. M) C RESULTS ARE RETURNED IN 1ST(M-1) ELEMENTS OF A,B,&C. C ALSO USED AS WORK ARRAYS DURING EXECUTION. C IT= TYPE OF BOUNDARY CONDITION SUPPLIED IN D ARRAY. USE C IT=1 IF 1ST DERIVATIVES GIVEN AT END POINTS, OR C IT=0 IF 2ND DERIVATIVES GIVEN AT END POINTS. C D= BOUNDARY ARRAY (DIM 2) AT POINT 1 AND M RESPECTIVELY. C P,S= WORK ARRAYS (EACH DIM=M). C--ERROR RETURN WITH M=-(ABS(M)) IF ANY PARM OUT OF RANGE. C THE RESULTING CUBIC SPLINE IS OF THE FORM: C Y=Y(I)+A(I)*(X-X(I))+B(I)*(X-X(I))**2+C(I)*(X-X(I))**3 C FOR I=1,2,...,M-1 C C REAL*4 X(1),Y(1),A(1),B(1),C(1),D(2),P(1),S(1),MUL IF(IT.LT.0.OR.IT.GT.1.OR.H.LT.0..OR.M.LT.3) GO TO 999 N=M-1 IF(IT.EQ.0) GO TO 20 C--1ST DERIVATIVE BOUNDARIES GIVEN NE=N-1 IF(H) 999,11,1 C--EQUAL SPACING H .GT. 0. AND IT=1 1 HH=3.0/H DO 2 I=1,NE B(I)=4.0 C(I)=1.0 A(I)=1.0 2 P(I)=HH*(Y(I+2)-Y(I)) P(1)=P(1)-D(1) P(NE)=P(NE)-D(2) C--SOLUTION OF TRIDIAGONAL MATRIX EQ. OF ORDER NE 3 C(1)=C(1)/B(1) P(1)=P(1)/B(1) DO 4 I=2,NE MUL=1.0/(B(I)-A(I)*C(I-1)) C(I)=MUL*C(I) 4 P(I)=MUL*(P(I)-A(I)*P(I-1)) C--OBTAIN SPLINE COEFFICIENTS A(NE+IT)=P(NE) I=NE-1 5 A(I+IT)=P(I)-C(I)*A(I+IT+1) I=I-1 IF(I.GE.1) GO TO 5 IF(IT.EQ.0) GO TO 6 A(1)=D(1) A(M)=D(2) 6 IF(H.EQ.0.) GO TO 14 HH=1.0/H DO 7 I=1,N MUL=HH*(Y(I+1)-Y(I)) B(I)=HH*(3.0*MUL-(A(I+1)+2.0*A(I))) 7 C(I)=HH*HH*(-2.0*MUL+A(I+1)+A(I)) RETURN C--UNEQUAL SPACING H=0.. AND IT=1 11 DO 12 I=1,N 12 S(I+1)=X(I+1)-X(I) DO 13 I=1,NE B(I)=2.0*(S(I+1)+S(I+2)) C(I)=S(I+1) A(I)=S(I+2) 13 P(I)=3.0*(S(I+1)**2*(Y(I+2)-Y(I+1))+S(I+2)**2*(Y(I+1)-Y(I)))/ $ (S(I+1)*S(I+2)) P(1)=P(1)-S(3)*D(1) P(NE)=P(NE)-S(N)*D(2) GO TO 3 14 DO 15 I=1,N HH=1.0/S(I+1) MUL=(Y(I+1)-Y(I))*HH**2 B(I)=3.0*MUL-(A(I+1)+2.0*A(I))*HH 15 C(I)=-2.0*MUL*HH+(A(I+1)+A(I))*HH**2 RETURN C--2ND DERIVATIVE BOUNDARIES GIVEN 20 NE=N+1 IF(H) 999,31,21 C--EQUAL SPACING H .GT. 0 AND IT=0 21 HH=3.0/H DO 22 I=2,N B(I)=4.0 C(I)=1.0 A(I)=1.0 22 P(I)=HH*(Y(I+1)-Y(I-1)) B(1)=2.0 B(NE)=2.0 C(1)=1.0 C(NE)=1.0 A(NE)=1.0 P(1)=HH*(Y(2)-Y(1))-0.5*H*D(1) P(NE)=HH*(Y(M)-Y(N))+0.5*H*D(2) GO TO 3 C--UNEQUAL SPACING H=0 AND IT=0 31 DO 32 I=1,N 32 S(I+1)=X(I+1)-X(I) N1=N-1 DO 33 I=1,N1 B(I+1)=2.0*(S(I+1)+S(I+2)) C(I+1)=S(I+1) A(I+1)=S(I+2) 33 P(I+1)=3.0*(S(I+1)**2*(Y(I+2)-Y(I+1))+S(I+2)**2*(Y(I+1)-Y(I)))/ * (S(I+1)*S(I+2)) B(1)=2.0 B(NE)=2.0 C(1)=1.0 C(NE)=1.0 A(NE)=1.0 P(1)=3.0*(Y(2)-Y(1))/S(2)-0.5*S(2)*D(1) P(NE)=3.0*(Y(M)-Y(N))/S(M)+0.5*S(M)*D(2) GO TO 3 999 M=-IABS(M) RETURN END SUBROUTINE SPOINT(M,X,Y,A,B,C,XX,YY) C--GIVEN CUBIC SPLINE COEFF'S A,B,C,AND M OBS.DATA ARRAYS X,Y C SPOINT EVALUATES THE PIECEWISE CUBIC SPLINE ORDINATE YY AT THE C ABSCISSA XX, WHERE XX IS IN THE CLOSED INTERVAL (X(1),X(M)). C NOTE: IF COMPUTING OVER EQUAL INTERVALS, USE THE SUBR 'CUBIC' C WHICH REQUIRES ONLY ONE CALL. C DIMENSION X(1),Y(1),A(1),B(1),C(1) IF(XX.LT.X(1).OR.XX.GT.X(M)) GO TO 9 M1=M-1 DO 1 I=1,M1 J=I IF(XX.LE.X(I+1)) GO TO 2 1 CONTINUE 9 WRITE(6,60) XX,X(1),X(M) 60 FORMAT('0ERROR IN SPOINT CALL--XX=',E16.8,' NOT IN CLOSED INTERVAL * (',E16.8,',',E16.8,')') RETURN 2 Z=XX-X(J) YY=Y(J)+((C(J)*Z+B(J))*Z+A(J))*Z RETURN END SUBROUTINE BESAUX(BESR,BESI,ORDER,NL,NU,R,FUN1,REL1,FWORK,MAXREL, $ RERR,AERR, NPCS,NEW,IERR) C C PERFORMS AUTOMATIC CALCULATION OF BESSEL TRANSFORM TO SPECIFIED C RELATIVE AND ABSOLUTE ERROR C C ARGUMENT LIST: C C BESR,BESI-REAL AND IMAGINARY PARTS RETURNED BY BESAUX C ORDER-ORDER OF THE BESSEL FUNCTION C NL-LOWER LIMIT FOR GAUSS ORDER TO START COMPUTATION C NU-UPPER LIMIT FOR GAUSS ORDER C NU,NL=1,...7 SELECTS 3,7,15,31,63,127,AND 255 POINT GAUSS C QUADRATURE BETWEEN THE ZERO CROSSINGS OF THE BESSEL FUNCTION C R-ARGUMENT OF THE BESSEL FUNCTION C/////////////////////////////////////////////////////////////////////// C THE FOLLOWING PARAMETERS ARE INCLUDED SO THAT BESAUX CAN BE RUN C UNDER THE GENERAL CONTROL OF SUBROUTINE HYBFHT: C/////////////////////////////////////////////////////////////////////// C FUN1 - NAME OF AN EXTERNAL DECLARED COMPLEX FUNCTION WRITTEN BY C THE USER TO EVALUATE FUN1(G) FOR G>0.0. AN EXTERNAL C STATEMENT MUST APPEAR IN THE USER'S CALLING PROGRAM AS: C EXTERNAL FUN1 C AND THE COMPLEX FUNCTION MUST HAVE THE GENERAL FORM: C (REPLACE "<...>" BELOW AS REQUIRED.) C C COMPLEX FUNCTION FUN1(G) C COMMON/PASS/<...INCLUDE PARAMETERS AS NEEDED...> C <...> C FUN1=CMPLX(<...>,<...>) C RETURN C END C C NOTES: SEE COMMENTS IN SUBROUTINES HYBFHT AND HANKL ON FUN1. C THE EXTERNAL FUNCT CALL WAS CHANGED FROM THE FORM: C CALL FUN1(X,YR,YI) -- ORIGINAL METHOD IN BESAUT -- TO C Z=FUN1(X), WHERE COMPLEX FUN1 USED IN BESAUX, BESTRX, AND C BESQUX. THIS METHOD WAS USED HERE TO BE COMPATIBLE WITH C EXTERNAL COMPLEX FUN1 USED IN CALL HANKL AND HYBFHT. C REL1 - NAME OF AN EXTERNAL DECLARED SUBROUTINE WRITTEN BY THE USER C TO EVALUATE ANY (AND ALL) NREL RELATED KERNELS FJ(NREL) C AS A FUNCTION OF F1=FUN1(G), ASSUMED PREVIOUSLY EVALUATED. C AN EXTERNAL STATEMENT MUST APPEAR IN THE USER'S PROGRAM AS: C EXTERNAL REL1 C AND THE SUBROUTINE MUST HAVE THE GENERAL FORM: C (REPLACE "<...>" BELOW AS REQUIRED.) C C SUBROUTINE REL1(G,F1,FJ,J) C COMPLEX F1,FJ(1) C COMMON/PASS/<...INCLUDE PARAMETERS AS NEEDED...> C IF(J.LT.0) GO TO (1,2,<...UP TO NREL...>), IABS(J) C 1 FJ(1)=F1 C IF(J.LT.0) RETURN C 2 FJ(2)= <...EXPRESSION IN TERMS OF G,F1, ETC...> C IF(J.LT.0) RETURN C <...> C RETURN C END C NOTES: C SEE COMMENTS IN SUBROUTINES HYBFHT AND HANKL ON REL1. C REL1 PARAMETERS G,F1,J ARE CONTROLLED BY SUBROUTINE BESAUX C WHERE THE USER MUST ONLY CODE THE FJ(J),J=1,NREL RELATED C KERNELS AS A FUNCTION OF G,F1, AND ANY OTHER PARAMETERS C THAT CAN BE PASSED IN COMMON/PASS/, AS REQUIRED. C FWORK - COMPLEX WORK ARRAY FWORK(MAXREL), WHICH IS USED IN CALL C TO REL1 AND PASSED TO BESAUX BY USER'S CALLING PROGRAM. C MAXREL - MAXIMUM DIMENSION OF FWORK(MAXREL) IN CALLING PROGRAM. C/////////////////////////////////////////////////////////////////////// C RERR,AERR-RELATIVE AND ABSOLUTE ERROR FOR TERMINATION C BESAUX TERMINATES WHEN INCREASING THE GAUSS ORDER DOES NOT C CHANGE THE RESULT BY MORE THAN RERR OR WHEN THE ABSOLUTE ERROR C IS LESS THAN AERR OR WHEN A GAUSS ORDER OF NU IS REACHED. C NPCS-NUMBER OF PIECES INTO WHICH EACH PARTIAL INTEGRAND IS DIVIDED, C ORDINARILY SET TO ONE. FOR VERY SMALL VALUES OF R WHERE C THE KERNEL FUNCTION IS APPRECIABLE ONLY OVER THE FIRST FEW C LOOPS OF THE BESSEL FUNCTION, NPCS MAY BE INCREASED TO ACHIEVE C REASONABLE ACCURACY. C NEW IF NEW=1, THE INTEGRANDS ARE COMPUTED AND SAVED AT EACH GAUSS C ORDER. IF NEW=2, PREVIOUSLY COMPUTED INTEGRANDS ARE USED. NOTE C THAT ORDER,R, AND NPCS MUST NOT BE CHANGED WHEN SETTING NEW=2. C IERR-ERROR PARAMETER C IERR=0--NORMAL RETURN C IERR=1--RESULT NOT ACCURATE TO RERR DUE TO TOO LOW A GAUSS C ORDER OR CONVERGENCE NOT ACHIEVED IN BESTRX C C SUBROUTINES REQUIRED: C BESTRX,BESQUX,JBESS,PADECF,CF,ZEROJ,DOT C C A.CHAVE IGPP/UCSD C IMPLICIT DOUBLE PRECISION (A-H,O-Z) DIMENSION XSUM(1) PARAMETER (NSUM=0) C COMMON /TEST/ CONTAINS RUN STATISTICS C NG=HIGHEST GAUSS ORDER USED C NF=TOTAL FUNCTION EVALUATIONS FOR ALL CALLS TO BESTRX C NI=TOTAL NUMBER OF PARTIAL INTEGRANDS ON LAST CALL C TO BESTRX ONLY COMMON /TEST/NG,NF,NI C// EXTERNAL COMPLEX FUN1 !20090922 EXTERNAL REL1 COMPLEX FWORK(MAXREL) C// NF=0 IF(NL.GT.NU)THEN BESR=0. BESI=0. IERR=1 RETURN ENDIF NW=MAX(NEW,1) CALL BESTRX(BESR,BESI,ORDER,NL,R,FUN1,REL1,FWORK,MAXREL, $ .1*RERR,.1*AERR, NPCS,XSUM,NSUM,NW,IERR) IF((IERR.NE.0).AND.(NL.EQ.7))THEN NG=NL RETURN ELSE OLDR=BESR OLDI=BESI DO 10 N=NL+1,NU CALL BESTRX(BESR,BESI,ORDER,N,R,FUN1,REL1,FWORK,MAXREL, $ .1*RERR,.1*AERR, NPCS,XSUM,NSUM,2,IERR) IF((IERR.NE.0).AND.(N.EQ.7))THEN BESR=OLDR BESI=OLDI NG=N RETURN ELSEIF((ABS(BESR-OLDR).LE.RERR*ABS(BESR)+AERR).AND.(ABS(BESI- $ OLDI).LE.RERR*ABS(BESI)+AERR))THEN NG=N RETURN ELSE OLDR=BESR OLDI=BESI ENDIF 10 CONTINUE ENDIF NG=7 IERR=1 RETURN END SUBROUTINE BESTRX(BESR,BESI,ORDER,NG,R,FUN1,REL1,FWORK,MAXREL, $ RERR,AERR,NPCS, XSUM,NSUM,NEW,IERR) C C COMPUTES BESSEL TRANSFORM OF SPECIFIED ORDER DEFINED AS C INTEGRAL(FUNCT(X)*J-SUB-ORDER(X*R)*DX) FROM X=0 TO INFINITY C COMPUTATION IS ACHIEVED BY INTEGRATION BETWEEN THE ASYMPTOTIC C ZERO CROSSINGS OF THE BESSEL FUNCTION USING GAUSS QUADRATURE. C THE RESULTING SERIES OF PARTIAL INTEGRANDS IS SUMMED BY CALCULATING C THE PADE APPROXIMANTS TO SPEED UP CONVERGENCE. C C ARGUMENT LIST: C C BESR,BESI REAL AND IMAGINARY PARTS RETURNED BY BESTRX C ORDER ORDER OF THE BESSEL FUNCTION C NG NUMBER OF GAUSS POINTS TO USE IN THE QUADRATURE ROUTINE. C NG=1 THROUGH 7 SELECTS 3,7,15,31,63,126,AND 255 TERMS. C R ARGUMENT OF THE BESSEL FUNCTION C/////////////////////////////////////////////////////////////////////// C PARAMETERS "FUN1,REL1,FWORK,MAXREL" ARE INCLUDED SO THAT BESAUX CAN C BE RUN UNDER THE GENERAL CONTROL OF SUBROUTINE HYBFHT. C (SEE SUBROUTINES BESAUX AND HYBFHT FOR DETAILS ON THESE PARAMETERS.) C/////////////////////////////////////////////////////////////////////// C RERR,AERR SPECIFIED RELATIVE AND ABSOLUTE ERROR FOR THE C CALCULATION. THE INTEGRATION C TERMINATES WHEN AN ADDITIONAL TERM DOES NOT CHANGE THE C RESULT BY MORE THAN RERR*RESULT+AERR C NPCS NUMBER OF PIECES INTO WHICH EACH PARTIAL INTEGRAND IS DIVIDED, C ORDINARILY SET TO ONE. FOR VERY SMALL VALUES OF RANGE WHERE C THE KERNEL FUNCTION IS APPRECIABLE ONLY OVER THE FIRST FEW C LOOPS OF THE BESSEL FUNCTION, NPCS MAY BE INCREASED TO ACHIEVE C REASONABLE ACCURACY. NOTE THAT NPCS AFFECTS ONLY THE PADE C SUM PORTION OF THE INTEGRATION, OVER X(NSUM) TO INFINITY. C XSUM VECTOR OF VALUES OF THE KERNEL ARGUMENT OF FUNCT FOR WHICH C EXPLICIT CALCULATION OF THE INTEGRAL IS DESIRED, SO THAT THE C INTEGRAL OVER 0 TO XSUM(NSUM) IS ADDED TO THE INTEGRAL OVER C XSUM(NSUM) TO INFINITY WITH THE PADE METHOD INVOKED ONLY FOR C THE LATTER. THIS ALLOWS THE PADE SUMMATION METHOD TO BE C OVERRIDDEN AND SOME TYPES OF SINGULARITIES TO BE HANDLED. C NSUM NUMBER OF VALUES IN XSUM, MAY BE ZERO. C NEW DETERMINES METHOD OF KERNEL CALCULATION C NEW=0 MEANS CALCULATE BUT DO NOT SAVE INTEGRANDS C NEW=1 MEANS CALCULATE KERNEL BY CALLING FUNCT-SAVE KERNEL C TIMES BESSEL FUNCTION C NEW=2 MEANS USE SAVED KERNELS TIMES BESSEL FUNCTIONS IN C COMMON /BESINT/. NOTE THAT ORDER,R,NPCS,XSUM, AND C NSUM MAY NOT BE CHANGED WHEN SETTING NEW=2. C IERR ERROR PARAMETER C 0 NORMAL RETURN-INTEGRAL CONVERGED C 1 MEANS NO CONVERGENCE AFTER NSTOP TERMS IN THE PADE SUM C C SUBROUTINES REQUIRED: C BESQUX,PADECF,CF,ZEROJ,DOT,JBESS C C A.CHAVE IGPP/UCSD C C NTERM IS MAXIMUM NUMBER OF BESSEL FUNCTION LOOPS STORED IF NEW.NE.0 C NSTOP IS MAXIMUM NUMBER OF PADE TERMS C PARAMETER (NTERM=50, NSTOP=100) IMPLICIT DOUBLE PRECISION (A-H,O-Z) DOUBLE PRECISION KARG,KERN,LASTR,LASTI,KBES DIMENSION KARG(255,NTERM),KERN(510,NTERM),SR(NSTOP),SI(NSTOP), $ NK(NTERM),XSUM(1),KBES(510,NTERM) C COMMON /TEST/ CONTAINS RUN STATISTICS C NGAUSS=HIGHEST GAUSS ORDER USED C NF=TOTAL FUNCTION EVALUATIONS FOR ALL CALLS TO BESTRX C NI=TOTAL NUMBER OF PARTIAL INTEGRANDS USED IN PADECF ON LAST CALL C TO BESTRX COMMON /TEST/NGAUSS,NF,NI C IF NEW.GT.0, COMMON /BESINT/ CONTAINS THE KERNEL FUNCTION ARGUMENTS C AND VALUES KARG(I,N),KERN(I,N) FOR N=1 TO NPS AND I=1 TO C 2**(NK(N)+1)-1. C KERN(I,N), KERN(I+1,N) CONTAIN THE REAL AND IMAGINARY PARTS OF THE C KERNEL FUNCTION FOR THE CORRESPONDING ARGUMENT VALUE KARG(I,N). C EACH VALUE OF N CORRESPONDS TO ONE ENTRY IN XSUM OR TO ONE INTERVAL C BETWEEN ZERO CROSSINGS OF THE BESSEL FUNCTION DIVIDED BY NPCS. C NOTE THAT UP TO NTERM VALUES ARE STORED THE INTEGRATION PROCEEDS C FOR N.GT.NTERM AS IF NEW=0. NP IS AN INDEX PASSED INTERNALLY BY C BESTRX. (KBES ADDED FOR HYBFHT CONTROL.) COMMON /BESINT/NK,NP,NPS,KARG,KERN,KBES C// EXTERNAL COMPLEX FUN1 !20090922 EXTERNAL REL1 COMPLEX FWORK(MAXREL) C// IF(NEW.EQ.2)THEN NPO=NPS ELSE DO 5 I=1,NTERM NK(I)=0 5 CONTINUE NPS=0 NPO=NTERM ENDIF C CHECK FOR TRIVIAL CASE IF((ORDER.NE.0.0).AND.(R.EQ.0.))THEN BESR=0. BESI=0. IERR=0 RETURN ENDIF NI=0 NW=NEW NP=1 NPB=1 L=1 B=0.0 SUMR=0.0 SUMI=0.0 XSUMR=0.0 XSUMI=0.0 IF(NSUM.GT.0)THEN C COMPUTE BESSEL TRANSFORM EXPLICITLY ON (0,XSUM(NSUM)) LASTR=0.0 LASTI=0.0 DO 10 N=1,NSUM IF((NW.EQ.2).AND.(NP.GT.NPO))NW=1 IF(NP.GT.NTERM)NW=0 A=B B=XSUM(N) CALL BESQUX(A,B,TERMR,TERMI,NG,NW,ORDER,R,FUN1,REL1, 1 FWORK,MAXREL) XSUMR=XSUMR+TERMR XSUMI=XSUMI+TERMI IF((ABS(XSUMR-LASTR).LE.RERR*ABS(XSUMR)+AERR).AND. $ (ABS(XSUMI-LASTI).LE.RERR*ABS(XSUMI)+AERR))THEN BESR=XSUMR BESI=XSUMI IERR=0 NPS=MAX(NP,NPS) RETURN ELSE NP=NP+1 LASTR=XSUMR LASTI=XSUMI ENDIF 10 CONTINUE C FIND FIRST ZERO CROSSING OF BESSEL FUNCTION BEYOND XSUM(NSUM) 15 CONTINUE IF(ZEROJ(NPB,ORDER).GT.XSUM(NSUM)*R)GOTO 20 NPB=NPB+1 GOTO 15 ENDIF C ENTRY POINT FOR PADE SUMMATION OF PARTIAL INTEGRANDS 20 CONTINUE LASTR=0.0 LASTI=0.0 A=B B=ZEROJ(NPB,ORDER)/R C CALCULATE TERMS AND SUM WITH PADECF, QUITTING WHEN CONVERGENCE IS C OBTAINED DO 30 N=1,NSTOP IF(NPCS.EQ.1)THEN IF((NW.EQ.2).AND.(NP.GT.NPO))NW=1 IF(NP.GT.NTERM)NW=0 CALL BESQUX(A,B,TERMR,TERMI,NG,NW,ORDER,R,FUN1,REL1, 1 FWORK,MAXREL) NP=NP+1 ELSE TERMR=0. TERMI=0. XINC=(B-A)/NPCS AA=A BB=A+XINC DO 25 I=1,NPCS IF((NW.EQ.2).AND.(NP.GT.NPO))NW=1 IF(NP.GT.NTERM)NW=0 CALL BESQUX(AA,BB,TR,TI,NG,NW,ORDER,R,FUN1,REL1, 1 FWORK,MAXREL) TERMR=TERMR+TR TERMI=TERMI+TI AA=BB BB=BB+XINC NP=NP+1 25 CONTINUE ENDIF NI=NI+1 SR(L)=TERMR SI(L)=TERMI CALL PADECF(SUMR,SUMI,SR,SI,L) IF((ABS(SUMR-LASTR).LE.RERR*ABS(SUMR)+AERR).AND. $ (ABS(SUMI-LASTI).LE.RERR*ABS(SUMI)+AERR))THEN BESR=XSUMR+SUMR BESI=XSUMI+SUMI IERR=0 NPS=MAX(NP-1,NPS) RETURN ELSE LASTR=SUMR LASTI=SUMI NPB=NPB+1 A=B B=ZEROJ(NPB,ORDER)/R L=L+1 ENDIF 30 CONTINUE BESR=XSUMR+SUMR BESI=XSUMI+SUMI IERR=1 NPS=MAX(NP,NPS) RETURN END SUBROUTINE BESQUX(A,B,BESR,BESI,NG,NEW,ORDER,R,FUN1,REL1, 1 FWORK,MAXREL) C C THIS SUBROUTINE CALCULATES THE INTEGRAL OF F(X)*J-SUB-N(X*R) C OVER THE INTERVAL A TO B AT A SPECIFIED GAUSS ORDER C THE RESULT IS OBTAINED USING A SEQUENCE OF 1,3,7,15,31,63, C 127, AND 255 POINT INTERLACING GAUSS FORMULAE SO THAT NO INTEGRAND C EVALUATIONS ARE WASTED. THE KERNEL FUNCTIONS MAY BE SAVED SO THAT C BESSEL TRANSFORMS OF SIMILAR KERNELS ARE COMPUTED WITHOUT NEW C EVALUATION OF THE KERNEL. C DETAILS ON THE FORMULAE ARE GIVEN IN 'THE OPTIMUM ADDITION OF POINTS C TO QUADRATURE FORMULAE' BY T.N.L. PATTERSON, MATHS.COMP. C 22,847-856 (1968). GAUSS WEIGHTS TAKEN FROM C COMM. A.C.M. 16,694-699 (1973) C C ARGUMENT LIST: C C A LOWER LIMIT OF INTEGRATION C B UPPER LIMIT OF INTEGRATION C BESR,BESI RETURNED INTEGRAL VALUE REAL AND IMAGINARY PARTS C NG NUMBER OF POINTS IN THE GAUSS FORMULA. NG=1,...7 C SELECTS 3,7,15,31,63,127,AND 255 POINT QUADRATURE. C NEW SELECTS METHOD OF KERNEL EVALUATION C NEW=0 CALCULATES KERNELS BY CALLING F - NOTHING SAVED C NEW=1 CALCULATES KERNELS BY CALLING F AND SAVES KERNEL TIMES C BESSEL FUNCTION IN COMMON /BESINT/ C NEW=2 USES SAVED KERNEL TIMES BESSEL FUNCTIONS IN C COMMON /BESINT/ C ORDER ORDER OF THE BESSEL FUNCTION C R ARGUMENT OF THE BESSEL FUNCTION C/////////////////////////////////////////////////////////////////////// C PARAMETERS "FUN1,REL1,FWORK,MAXREL" ARE INCLUDED SO THAT BESAUX CAN C BE RUN UNDER THE GENERAL CONTROL OF SUBROUTINE HYBFHT. C (SEE SUBROUTINES BESAUX AND HYBFHT FOR DETAILS ON THESE PARAMETERS.) C/////////////////////////////////////////////////////////////////////// C// C// NOTE: C// SINGLE-PRESISION COMPLEX FOR BESAUX AT FUN1 LEVEL ONLY/ C// C// (SEE USE OF ZFUN1 AND FUN1 BELOW AS BOUNDED BY C// LINES.) C/////////////////////////////////////////////////////////////////////// C C A.CHAVE IGPP/UCSD C C MAXIMUM NUMBER OF BESSEL FUNCTION LOOPS THAT CAN BE SAVED PARAMETER (NTERM=50) IMPLICIT DOUBLE PRECISION (A-H,O-Z) C// COMPLEX ZFUN1,FWORK(MAXREL) !20090922 COMMON/CONTRL/JPATH,JREL EXTERNAL COMPLEX FUN1 !20090922 EXTERNAL REL1 C// DOUBLE PRECISION KARG,KERN,JBESS,KBES DIMENSION WT(254),WA(127),NWA(7),NWT(7),KARG(255,NTERM), $ KERN(510,NTERM),FUNCT(254),FR1(64),FI1(64),FR2(64), $ FI2(64),BES1(64),BES2(64),NK(NTERM),KBES(510,NTERM) C COMMON /TEST/ CONTAINS RUN STATISTICS C NGAUSS=HIGHEST GAUSS ORDER USED C NF=TOTAL FUNCTION EVALUATIONS FOR ALL CALLS TO BESTRX C NI=TOTAL NUMBER OF PARTIAL INTEGRANDS ON LAST CALL C TO BESTRX ONLY COMMON /TEST/NGAUSS,NF,NI COMMON /BESINT/NK,NP,NPS,KARG,KERN,KBES C STARTING ADDRESSES IN ARRAYS WT AND WA AT EACH ORDER DATA NWT/1,3,7,15,31,63,127/,NWA/1,2,4,8,16,32,64/ C ARRAY WT CONTAINS GAUSS QUADRATURE WEIGHTS STORED AS NEEDED AT C EACH ORDER. ARRAY WA CONTAINS THE CORRESPONDING ARGUMENT WEIGHTS. DATA (WT(I),I=1,20)/ $0.55555555555555555556D+00,0.88888888888888888889D+00, $0.26848808986833344073D+00,0.10465622602646726519D+00, $0.40139741477596222291D+00,0.45091653865847414235D+00, $0.13441525524378422036D+00,0.51603282997079739697D-01, $0.20062852937698902103D+00,0.17001719629940260339D-01, $0.92927195315124537686D-01,0.17151190913639138079D+00, $0.21915685840158749640D+00,0.22551049979820668739D+00, $0.67207754295990703540D-01,0.25807598096176653565D-01, $0.10031427861179557877D+00,0.84345657393211062463D-02, $0.46462893261757986541D-01,0.85755920049990351154D-01/ DATA (WT(I),I=21,40)/ $0.10957842105592463824D+00,0.25447807915618744154D-02, $0.16446049854387810934D-01,0.35957103307129322097D-01, $0.56979509494123357412D-01,0.76879620499003531043D-01, $0.93627109981264473617D-01,0.10566989358023480974D+00, $0.11195687302095345688D+00,0.11275525672076869161D+00, $0.33603877148207730542D-01,0.12903800100351265626D-01, $0.50157139305899537414D-01,0.42176304415588548391D-02, $0.23231446639910269443D-01,0.42877960025007734493D-01, $0.54789210527962865032D-01,0.12651565562300680114D-02, $0.82230079572359296693D-02,0.17978551568128270333D-01/ DATA (WT(I),I=41,60)/ $0.28489754745833548613D-01,0.38439810249455532039D-01, $0.46813554990628012403D-01,0.52834946790116519862D-01, $0.55978436510476319408D-01,0.36322148184553065969D-03, $0.25790497946856882724D-02,0.61155068221172463397D-02, $0.10498246909621321898D-01,0.15406750466559497802D-01, $0.20594233915912711149D-01,0.25869679327214746911D-01, $0.31073551111687964880D-01,0.36064432780782572640D-01, $0.40715510116944318934D-01,0.44914531653632197414D-01, $0.48564330406673198716D-01,0.51583253952048458777D-01, $0.53905499335266063927D-01,0.55481404356559363988D-01/ DATA (WT(I),I=61,80)/ $0.56277699831254301273D-01,0.56377628360384717388D-01, $0.16801938574103865271D-01,0.64519000501757369228D-02, $0.25078569652949768707D-01,0.21088152457266328793D-02, $0.11615723319955134727D-01,0.21438980012503867246D-01, $0.27394605263981432516D-01,0.63260731936263354422D-03, $0.41115039786546930472D-02,0.89892757840641357233D-02, $0.14244877372916774306D-01,0.19219905124727766019D-01, $0.23406777495314006201D-01,0.26417473395058259931D-01, $0.27989218255238159704D-01,0.18073956444538835782D-03, $0.12895240826104173921D-02,0.30577534101755311361D-02/ DATA (WT(I),I=81,100)/ $0.52491234548088591251D-02,0.77033752332797418482D-02, $0.10297116957956355524D-01,0.12934839663607373455D-01, $0.15536775555843982440D-01,0.18032216390391286320D-01, $0.20357755058472159467D-01,0.22457265826816098707D-01, $0.24282165203336599358D-01,0.25791626976024229388D-01, $0.26952749667633031963D-01,0.27740702178279681994D-01, $0.28138849915627150636D-01,0.50536095207862517625D-04, $0.37774664632698466027D-03,0.93836984854238150079D-03, $0.16811428654214699063D-02,0.25687649437940203731D-02, $0.35728927835172996494D-02,0.46710503721143217474D-02/ DATA (WT(I),I=101,120)/ $0.58434498758356395076D-02,0.70724899954335554680D-02, $0.83428387539681577056D-02,0.96411777297025366953D-02, $0.10955733387837901648D-01,0.12275830560082770087D-01, $0.13591571009765546790D-01,0.14893641664815182035D-01, $0.16173218729577719942D-01,0.17421930159464173747D-01, $0.18631848256138790186D-01,0.19795495048097499488D-01, $0.20905851445812023852D-01,0.21956366305317824939D-01, $0.22940964229387748761D-01,0.23854052106038540080D-01, $0.24690524744487676909D-01,0.25445769965464765813D-01, $0.26115673376706097680D-01,0.26696622927450359906D-01/ DATA (WT(I),I=121,140)/ $0.27185513229624791819D-01,0.27579749566481873035D-01, $0.27877251476613701609D-01,0.28076455793817246607D-01, $0.28176319033016602131D-01,0.28188814180192358694D-01, $0.84009692870519326354D-02,0.32259500250878684614D-02, $0.12539284826474884353D-01,0.10544076228633167722D-02, $0.58078616599775673635D-02,0.10719490006251933623D-01, $0.13697302631990716258D-01,0.31630366082226447689D-03, $0.20557519893273465236D-02,0.44946378920320678616D-02, $0.71224386864583871532D-02,0.96099525623638830097D-02, $0.11703388747657003101D-01,0.13208736697529129966D-01/ DATA (WT(I),I=141,160)/ $0.13994609127619079852D-01,0.90372734658751149261D-04, $0.64476204130572477933D-03,0.15288767050877655684D-02, $0.26245617274044295626D-02,0.38516876166398709241D-02, $0.51485584789781777618D-02,0.64674198318036867274D-02, $0.77683877779219912200D-02,0.90161081951956431600D-02, $0.10178877529236079733D-01,0.11228632913408049354D-01, $0.12141082601668299679D-01,0.12895813488012114694D-01, $0.13476374833816515982D-01,0.13870351089139840997D-01, $0.14069424957813575318D-01,0.25157870384280661489D-04, $0.18887326450650491366D-03,0.46918492424785040975D-03/ DATA (WT(I),I=161,180)/ $0.84057143271072246365D-03,0.12843824718970101768D-02, $0.17864463917586498247D-02,0.23355251860571608737D-02, $0.29217249379178197538D-02,0.35362449977167777340D-02, $0.41714193769840788528D-02,0.48205888648512683476D-02, $0.54778666939189508240D-02,0.61379152800413850435D-02, $0.67957855048827733948D-02,0.74468208324075910174D-02, $0.80866093647888599710D-02,0.87109650797320868736D-02, $0.93159241280693950932D-02,0.98977475240487497440D-02, $0.10452925722906011926D-01,0.10978183152658912470D-01, $0.11470482114693874380D-01,0.11927026053019270040D-01/ DATA (WT(I),I=181,200)/ $0.12345262372243838455D-01,0.12722884982732382906D-01, $0.13057836688353048840D-01,0.13348311463725179953D-01, $0.13592756614812395910D-01,0.13789874783240936517D-01, $0.13938625738306850804D-01,0.14038227896908623303D-01, $0.14088159516508301065D-01,0.69379364324108267170D-05, $0.53275293669780613125D-04,0.13575491094922871973D-03, $0.24921240048299729402D-03,0.38974528447328229322D-03, $0.55429531493037471492D-03,0.74028280424450333046D-03, $0.94536151685852538246D-03,0.11674841174299594077D-02, $0.14049079956551446427D-02,0.16561127281544526052D-02/ DATA (WT(I),I=201,220)/ $0.19197129710138724125D-02,0.21944069253638388388D-02, $0.24789582266575679307D-02,0.27721957645934509940D-02, $0.30730184347025783234D-02,0.33803979910869203823D-02, $0.36933779170256508183D-02,0.40110687240750233989D-02, $0.43326409680929828545D-02,0.46573172997568547773D-02, $0.49843645647655386012D-02,0.53130866051870565663D-02, $0.56428181013844441585D-02,0.59729195655081658049D-02, $0.63027734490857587172D-02,0.66317812429018878941D-02, $0.69593614093904229394D-02,0.72849479805538070639D-02, $0.76079896657190565832D-02,0.79279493342948491103D-02/ DATA (WT(I),I=221,240)/ $0.82443037630328680306D-02,0.85565435613076896192D-02, $0.88641732094824942641D-02,0.91667111635607884067D-02, $0.94636899938300652943D-02,0.97546565363174114611D-02, $0.10039172044056840798D-01,0.10316812330947621682D-01, $0.10587167904885197931D-01,0.10849844089337314099D-01, $0.11104461134006926537D-01,0.11350654315980596602D-01, $0.11588074033043952568D-01,0.11816385890830235763D-01, $0.12035270785279562630D-01,0.12244424981611985899D-01, $0.12443560190714035263D-01,0.12632403643542078765D-01, $0.12810698163877361967D-01,0.12978202239537399286D-01/ DATA (WT(I),I=241,254)/ $0.13134690091960152836D-01,0.13279951743930530650D-01, $0.13413793085110098513D-01,0.13536035934956213614D-01, $0.13646518102571291428D-01,0.13745093443001896632D-01, $0.13831631909506428676D-01,0.13906019601325461264D-01, $0.13968158806516938516D-01,0.14017968039456608810D-01, $0.14055382072649964277D-01,0.14080351962553661325D-01, $0.14092845069160408355D-01,0.14094407090096179347D-01/ DATA (WA(I),I=1,20)/ $0.77459666924148337704D+00,0.96049126870802028342D+00, $0.43424374934680255800D+00,0.99383196321275502221D+00, $0.88845923287225699889D+00,0.62110294673722640294D+00, $0.22338668642896688163D+00,0.99909812496766759766D+00, $0.98153114955374010687D+00,0.92965485742974005667D+00, $0.83672593816886873550D+00,0.70249620649152707861D+00, $0.53131974364437562397D+00,0.33113539325797683309D+00, $0.11248894313318662575D+00,0.99987288812035761194D+00, $0.99720625937222195908D+00,0.98868475754742947994D+00, $0.97218287474858179658D+00,0.94634285837340290515D+00/ DATA (WA(I),I=21,40)/ $0.91037115695700429250D+00,0.86390793819369047715D+00, $0.80694053195021761186D+00,0.73975604435269475868D+00, $0.66290966002478059546D+00,0.57719571005204581484D+00, $0.48361802694584102756D+00,0.38335932419873034692D+00, $0.27774982202182431507D+00,0.16823525155220746498D+00, $0.56344313046592789972D-01,0.99998243035489159858D+00, $0.99959879967191068325D+00,0.99831663531840739253D+00, $0.99572410469840718851D+00,0.99149572117810613240D+00, $0.98537149959852037111D+00,0.97714151463970571416D+00, $0.96663785155841656709D+00,0.95373000642576113641D+00/ DATA (WA(I),I=41,60)/ $0.93832039777959288365D+00,0.92034002547001242073D+00, $0.89974489977694003664D+00,0.87651341448470526974D+00, $0.85064449476835027976D+00,0.82215625436498040737D+00, $0.79108493379984836143D+00,0.75748396638051363793D+00, $0.72142308537009891548D+00,0.68298743109107922809D+00, $0.64227664250975951377D+00,0.59940393024224289297D+00, $0.55449513263193254887D+00,0.50768775753371660215D+00, $0.45913001198983233287D+00,0.40897982122988867241D+00, $0.35740383783153215238D+00,0.30457644155671404334D+00, $0.25067873030348317661D+00,0.19589750271110015392D+00/ DATA (WA(I),I=61,80)/ $0.14042423315256017459D+00,0.84454040083710883710D-01, $0.28184648949745694339D-01,0.99999759637974846462D+00, $0.99994399620705437576D+00,0.99976049092443204733D+00, $0.99938033802502358193D+00,0.99874561446809511470D+00, $0.99780535449595727456D+00,0.99651414591489027385D+00, $0.99483150280062100052D+00,0.99272134428278861533D+00, $0.99015137040077015918D+00,0.98709252795403406719D+00, $0.98351865757863272876D+00,0.97940628167086268381D+00, $0.97473445975240266776D+00,0.96948465950245923177D+00, $0.96364062156981213252D+00,0.95718821610986096274D+00/ DATA (WA(I),I=81,100)/ $0.95011529752129487656D+00,0.94241156519108305981D+00, $0.93406843615772578800D+00,0.92507893290707565236D+00, $0.91543758715576504064D+00,0.90514035881326159519D+00, $0.89418456833555902286D+00,0.88256884024734190684D+00, $0.87029305554811390585D+00,0.85735831088623215653D+00, $0.84376688267270860104D+00,0.82952219463740140018D+00, $0.81462878765513741344D+00,0.79909229096084140180D+00, $0.78291939411828301639D+00,0.76611781930376009072D+00, $0.74869629361693660282D+00,0.73066452124218126133D+00, $0.71203315536225203459D+00,0.69281376977911470289D+00/ DATA (WA(I),I=101,120)/ $0.67301883023041847920D+00,0.65266166541001749610D+00, $0.63175643771119423041D+00,0.61031811371518640016D+00, $0.58836243444766254143D+00,0.56590588542365442262D+00, $0.54296566649831149049D+00,0.51955966153745702199D+00, $0.49570640791876146017D+00,0.47142506587165887693D+00, $0.44673538766202847374D+00,0.42165768662616330006D+00, $0.39621280605761593918D+00,0.37042208795007823014D+00, $0.34430734159943802278D+00,0.31789081206847668318D+00, $0.29119514851824668196D+00,0.26424337241092676194D+00, $0.23705884558982972721D+00,0.20966523824318119477D+00/ DATA (WA(I),I=121,127)/ $0.18208649675925219825D+00,0.15434681148137810869D+00, $0.12647058437230196685D+00,0.98482396598119202090D-01, $0.70406976042855179063D-01,0.42269164765363603212D-01, $0.14093886410782462614D-01/ C CHECK FOR TRIVIAL CASE IF(A.GE.B)THEN BESR=0. BESI=0. RETURN ENDIF IF(NEW.EQ.2)GOTO 200 C SCALE FACTORS SUM=(B+A)/2. DIFF=(B-A)/2. C ONE POINT GAUSS C// C// CALL F(SUM,FZEROR,FZEROI) ZFUN1=FUN1(SNGL(SUM)) IF(NEW.GE.1) THEN CALL REL1(SNGL(SUM),ZFUN1,FWORK,-JREL) ZFUN1=FWORK(JREL) ENDIF FZEROR=REAL(ZFUN1) FZEROI=AIMAG(ZFUN1) C// NF=NF+1 BESF=JBESS(SUM*R,ORDER) FZEROR=BESF*FZEROR FZEROI=BESF*FZEROI IF(NEW.EQ.1)THEN KARG(1,NP)=SUM KERN(1,NP)=FZEROR KERN(2,NP)=FZEROI C// KBES(1,NP)=BESF C// LA=2 LK=3 ENDIF N=1 KN=1 5 CONTINUE C STEP THROUGH GAUSS ORDERS DO 40 K=KN,NG C COMPUTE NEW FUNCTION VALUES NA=NWA(K) DO 10 J=1,NWA(K) X=WA(NA)*DIFF NA=NA+1 SUMP=SUM+X SUMM=SUM-X C// C// CALL F(SUMP,FR1(J),FI1(J)) ZFUN1=FUN1(SNGL(SUMP)) IF(NEW.GE.1) THEN CALL REL1(SNGL(SUMP),ZFUN1,FWORK,-JREL) ZFUN1=FWORK(JREL) ENDIF FR1(J)=REAL(ZFUN1) FI1(J)=AIMAG(ZFUN1) C// CALL F(SUMM,FR2(J),FI2(J)) ZFUN1=FUN1(SNGL(SUMM)) IF(NEW.GE.1) THEN CALL REL1(SNGL(SUMM),ZFUN1,FWORK,-JREL) ZFUN1=FWORK(JREL) ENDIF FR2(J)=REAL(ZFUN1) FI2(J)=AIMAG(ZFUN1) C// NF=NF+2 BES1(J)=JBESS(SUMP*R,ORDER) BES2(J)=JBESS(SUMM*R,ORDER) IF(NEW.GE.1)THEN KARG(LA,NP)=SUMP KARG(LA+1,NP)=SUMM C// KBES(LA,NP)=BES1(J) KBES(LA+1,NP)=BES2(J) C// LA=LA+2 ENDIF 10 CONTINUE C COMPUTE PRODUCTS OF KERNELS AND BESSEL FUNCTIONS DO 20 J=1,NWA(K) FR1(J)=BES1(J)*FR1(J) FI1(J)=BES1(J)*FI1(J) FR2(J)=BES2(J)*FR2(J) FI2(J)=BES2(J)*FI2(J) FUNCT(N)=FR1(J)+FR2(J) FUNCT(N+1)=FI1(J)+FI2(J) N=N+2 20 CONTINUE IF(NEW.GE.1)THEN DO 30 J=1,NWA(K) KERN(LK,NP)=FR1(J) KERN(LK+1,NP)=FI1(J) KERN(LK+2,NP)=FR2(J) KERN(LK+3,NP)=FI2(J) LK=LK+4 30 CONTINUE ENDIF 40 CONTINUE C COMPUTE DOT PRODUCT OF WEIGHTS WITH INTEGRAND VALUES NW=NWT(NG) C DOT SHOULD BE REPLACED WITH SDOT FROM SCILIB ON CRAY-1 IF D.P. IS C NOT USED ACUMR=DOT(NW,WT(NW),1,FUNCT(1),2) ACUMI=DOT(NW,WT(NW),1,FUNCT(2),2) BESR=(ACUMR+WT(2*NW)*FZEROR)*DIFF BESI=(ACUMI+WT(2*NW)*FZEROI)*DIFF IF(NP.LE.NTERM)NK(NP)=NG RETURN 200 CONTINUE C CONSTRUCT FUNCT FROM SAVED KERNELS DIFF=(B-A)/2. FZEROR=KERN(1,NP) FZEROI=KERN(2,NP) K=MIN(NK(NP),NG) NW=NWT(K) LK=3 DO 210 N=1,2*NW,2 FUNCT(N)=KERN(LK,NP)+KERN(LK+2,NP) FUNCT(N+1)=KERN(LK+1,NP)+KERN(LK+3,NP) LK=LK+4 210 CONTINUE IF(NK(NP).GE.NG)THEN C NO ADDITIONAL ORDERS REQUIRED-COMPUTE DOT PRODUCT OF WEIGHTS WITH C INTEGRAND VALUES AND RETURN ACUMR=DOT(NW,WT(NW),1,FUNCT(1),2) ACUMI=DOT(NW,WT(NW),1,FUNCT(2),2) BESR=(ACUMR+WT(2*NW)*FZEROR)*DIFF BESI=(ACUMI+WT(2*NW)*FZEROI)*DIFF RETURN ELSE C COMPUTE ADDITIONAL ORDERS BEFORE TAKING DOT PRODUCT SUM=(B+A)/2. KN=K+1 LA=LK/2+1 GOTO 5 ENDIF END SUBROUTINE PADECF(SUMR,SUMI,SR,SI,N) C C COMPUTES SUM(S(I)),I=1,...N BY COMPUTATION OF PADE APPROXIMANT C USING CONTINUED FRACTION EXPANSION. FUNCTION IS DESIGNED TO BE C CALLED SEQUENTIALLY AS N IS INCREMENTED FROM 1 TO ITS FINAL VALUE. C THE NTH CONTINUED FRACTION COEFFICIENT IS CALCULATED AND C STORED AND THE NTH CONVERGENT RETURNED. IT IS UP TO THE USER TO C STOP THE CALCULATION WHEN THE DESIRED ACCURACY IS ACHIEVED. C ALGORITHM FROM HANGGI ET AL., Z.NATURFORSCH. 33A,402-417 (1977) C IN THEIR NOTATION, VECTORS CFCOR,CFCOI ARE LOWER CASE D, VECTORS DR, C DI ARE UPPER CASE D, VECTORS XR,XI ARE X, AND VECTORS SR,SI ARE S C C A.CHAVE IGPP/UCSD C PARAMETER (NC=100) IMPLICIT DOUBLE PRECISION (A-H,O-Z) SAVE XR,XI,DR,DI,CFCOR,CFCOI DIMENSION SR(1),SI(1),XR(NC),XI(NC),DR(0:NC),DI(0:NC),CFCOR(NC), $ CFCOI(NC) DATA DR(0)/-1./,DI(0)/0./ IF(N.LT.3)THEN C INITIALIZE FOR RECURSIVE CALCULATIONS IF(N.EQ.1)THEN DO 10 I=1,NC XR(I)=0. XI(I)=0. 10 CONTINUE ENDIF DR(N)=SR(N) DI(N)=SI(N) DENOM=DR(N-1)**2+DI(N-1)**2 CFCOR(N)=-(DR(N-1)*DR(N)+DI(N-1)*DI(N))/DENOM CFCOI(N)=-(DR(N-1)*DI(N)-DR(N)*DI(N-1))/DENOM CALL CF(SUMR,SUMI,CFCOR,CFCOI,N) RETURN ELSE L=2*INT((N-1)/2) C UPDATE X VECTORS FOR RECURSIVE CALCULATION OF CF COEFFICIENTS DO 20 K=L,4,-2 XR(K)=XR(K-1)+CFCOR(N-1)*XR(K-2)-CFCOI(N-1)*XI(K-2) XI(K)=XI(K-1)+CFCOR(N-1)*XI(K-2)+CFCOI(N-1)*XR(K-2) 20 CONTINUE XR(2)=XR(1)+CFCOR(N-1) XI(2)=XI(1)+CFCOI(N-1) C INTERCHANGE ODD AND EVEN PARTS DO 30 K=1,MAX(1,L-1),2 T1=XR(K) T2=XI(K) XR(K)=XR(K+1) XI(K)=XI(K+1) XR(K+1)=T1 XI(K+1)=T2 30 CONTINUE C COMPUTE FIRST COEFFICIENTS DR(N)=SR(N) DI(N)=SI(N) DO 40 K=1,MAX(1,L/2) DR(N)=DR(N)+SR(N-K)*XR(2*K-1)-SI(N-K)*XI(2*K-1) DI(N)=DI(N)+SI(N-K)*XR(2*K-1)+SR(N-K)*XI(2*K-1) 40 CONTINUE C COMPUTE NEW CF COEFFICIENT DENOM=DR(N-1)**2+DI(N-1)**2 CFCOR(N)=-(DR(N)*DR(N-1)+DI(N)*DI(N-1))/DENOM CFCOI(N)=-(DR(N-1)*DI(N)-DR(N)*DI(N-1))/DENOM C EVALUATE CONTINUED FRACTION CALL CF(SUMR,SUMI,CFCOR,CFCOI,N) RETURN ENDIF END SUBROUTINE CF(RESR,RESI,CFCOR,CFCOI,N) C C EVALUATES A COMPLEX CONTINUED FRACTION BY RECURSIVE DIVISION C STARTING AT THE BOTTOM, AS USED BY PADECF C RESR,RESI ARE REAL AND IMAGINARY PARTS RETURNED C CFCOR,CFCOI ARE REAL AND IMAGINARY VECTORS OF CONTINUED FRACTION C COEFFICIENTS C PARAMETER (NC=100,NCM=NC-1) IMPLICIT DOUBLE PRECISION (A-H,O-Z) DIMENSION CFCOR(1),CFCOI(1),ONE(NC) DATA ONE/0.,NCM*1./ RESR=ONE(N)+C
The statement:
doesn't do what you think it does. It declares a name COMPLEXFUN1 as EXTERNAL. You could write:
COMPLEX,EXTERNAL :: FUN1
or
COMPLEX FUN1
EXTERNAL FUN1
You only get the error when generated interface checking is enabled.
or
COMPLEX FUN1
EXTERNAL FUN1
Quoting - Leigh Wardle
[plain] Hi,
1 FWORK,MAXREL)
Leigh
[/plain]
I forgot to mention:
- This code compiled succesfully with v10.1 - but in all declarations FUN1 was declared with the attribute COMPLEX.
- I am now compiling with the latest version of the compiler, v.11.1.046 Update 2.
The statement:
or
COMPLEX FUN1
EXTERNAL FUN1
or
COMPLEX FUN1
EXTERNAL FUN1
Quoting - Steve Lionel (Intel)
The statement:
or
COMPLEX FUN1
EXTERNAL FUN1
or
COMPLEX FUN1
EXTERNAL FUN1
Thanks, Steve, for setting me straight.
I am fascinated that the Fortran declaration EXTERNAL COMPLEX FUN1 declares a name COMPLEXFUN1 as EXTERNAL.
Leigh
It wouldn't if you used free-form source, which I recommend to all. I recognize that if you are dealing with existing fixed-form source that it may not make sense to change it, but in free form source this would have been caught as an error by the compiler.
In fixed-form sources, blanks are ignored in nearly all contexts. A very famous error, said to have brought down a spacecraft, was coding a DO loop like this:
DO I=1.10
where a dot instead of a comma was used. In fixed-form source, this is the same as:
DOI = 1.10
IMPLICIT NONE would also help you here.
