29607 Discussions
error #7002: Error in opening the compiled module file. Check INCLUDE paths
xuwanqing
when i am going to converting a program from cvf to ivf, then come to error #7002: Error in opening the compiled module file. Check INCLUDE paths.
program:
subroutine acd
use ran_mod
use input
in cvf,the ran_mod is a module to create Random numbers,and the cvf contain it.but i don't know what is the random module in ivf.
mecej4
Neither ran_mod.mod nor input.mod is present in my CVF 6.6 installation. I suspect that these were user-provided/generated module files. You could search for the source files in which these modules are declared and try compiling them. Alternatively, you could comment out the corresponding USE statements and obtain a list of missing external names at link time.
A number of non-standard random number related routines were provided in DFLIB.
Which versions of CVF and IFort are you using?
Steve_Lionel
There was no ran_mod provided by CVF.
My advice is to use the Fortran intrinsic procedure RANDOM_NUMBER (along with RANDOM_SEED if you need it.)
