29382 Discussions
error #7950: Procedure name in MODULE PROCEDURE statement must be the name of accessible module procedure. [FUNC]
milenko1976
I am having problem with this,I have adapted some Press subroutines.I am giving part of the code:
module minmod
interface func
module procedure func
end interface func
interface dfunc
module procedure dfunc
end interface dfunc
contains
subroutine dfpmin(p,gtol,iter,fret,func,dfunc)
use nrtype
use nr, only: lnsrch
use nre
use otp
use um
use vl
use funkcija
use izvod
I get this:minmod.f90(79): error #7950: Procedure name in MODULE PROCEDURE statement must be the name of accessible module procedure. [FUNC]
function func(x)
minmod.f90(5): error #7950: Procedure name in MODULE PROCEDURE statement must be the name of accessible module procedure. [DFUNC]
interface dfunc
minmod.f90(5): error #7407: Unresolved MODULE PROCEDURE specification name. [DFUNC]
interface dfunc
module funkcija
use cons
contains
function func(p)
implicit none
real,dimension(:),intent(in) :: p
real(kind(1d0)) func
real(kind(1d0)) row_sum, total
real,dimension(s) :: dist_ik
vv = reshape(p, (/ c,s /))
total = 0d0
do k=1,n_data
row_sum = 0d0
do i = 1, c
dist_ik = vv(i,:)-x(k,:)
row_sum = 1.0/dot_product(dist_ik, dist_ik) + row_sum
end do
total = 1d0/row_sum + total
end do
func= total
write(*,*)vv
end function func
end module funkcija
Please try to come up with a small but complete source that reproduces the problem. There's not enough here so far to be able to help.
milenko1976
I have mangaed to solve this.
milenko1976
But again I am having same problem with this module.
milenko@milenkons:~/primeri/a1$ ifort -g -traceback -c minmod.f90
minmod.f90(17): error #6645: The name of the module procedure conflicts with a name in the encompassing scoping unit. [DFPMIN]
minmod.f90(12): error #7950: Procedure name in MODULE PROCEDURE statement must be the name of accessible module procedure. [DFPMIN]
module procedure dfpmin
minmod.f90(33): error #6404: This name does not have a type, and must have an explicit type. [DFUNC]
g=dfunc(p)
compilation aborted for minmod.f90 (code 1)
milenko1976
These are files also necessary.
Source minmod.f90 uses module lintr which uses nr. nr defines an interface for DFPMIN so it is not allowed for you to also define DFPMIN in minmod.f90. You can get around this by changing the USE line in minmod.f90 to be:
use lintr, dummy=>dfpmin
The complaint about DFUNC not having a type is correct - you have not declared DFUNC inside dfpmin.
milenko1976
I see now,thanks Steve.
milenko1976
Regarding dfunc I still have problems.
milenko@milenkons:~/primeri/a2$ ifort -g -traceback -c minmod.f90
minmod.f90(24): error #6406: Conflicting attributes or multiple declaration of name. [DFUNC]
real(sp),dimension(size(p)),external :: dfunc
I have get rid of nr,I am attaching last version of code.
Sorry, we're having a problem with attachments right now. If the code is short, you can post it inline (use the "pencil" code insertion tool.) But you should be able to look for declarations of DFUNC and see if it is declared twice.
milenko1976
This is after grep:
/home/milenko/primeri/a4/izvod.f90:5:interface dfunc
/home/milenko/primeri/a4/izvod.f90:6:module procedure dfunc
/home/milenko/primeri/a4/izvod.f90:7:end interface dfunc
/home/milenko/primeri/a4/izvod.f90:9:function dfunc(p)
/home/milenko/primeri/a4/izvod.f90:12:real(sp),dimension(size(p)) :: dfunc
/home/milenko/primeri/a4/izvod.f90:37:dfunc=dv
Binary file /home/milenko/primeri/a4/izvod.o matches
/home/milenko/primeri/a4/minmod.f90:17:subroutine dfpmin(p,gtol,iter,fret,func,dfunc)
/home/milenko/primeri/a4/minmod.f90:24:real(sp),dimension(size(p)),external :: dfunc
/home/milenko/primeri/a4/minmod.f90:34:g=dfunc(p)
/home/milenko/primeri/a4/minmod.f90:46:g=dfunc(p)
module izvod
use cons
use nrtype
use ds
interface dfunc
end interface dfunc
contains
function dfunc(p)
implicit none
real(sp),dimension(:),intent(in) :: p
do i=1,c
do k=1,n_data
work_s=vv(i,:)-x(k,:)
work_cn(i,k)=1.0/dot_product(work_s,work_s)
end do
end do
write(*,*)work_cn
do k=1,n_data
work_n(k)=double_sum(work_cn(:,k))
end do
write(*,*)work_n
do i=1,c
work1_n=(work_cn(i,:)/work_n)**2
do k=1,s
dvv(i,k)=(double_sum(work1_n*vv(i,k))-double_sum(work1_n*x(i,k)))*2.0
end do
end do
dv=reshape(dvv,(/c*s/))
write(*,*)dv
dfunc=dv
end function
end module izvod
module minmod
use nrtype
use nre
use otp
use um
use lintr
use vl
use funkcija
use izvod
interface djs
end interface djs
contains
implicit none
integer(i4b), intent(out) :: iter
real(sp), intent(in) :: gtol
real(sp), intent(out) :: fret
real(sp), dimension(:), intent(inout) :: p
real(kind(1d0)),external :: func
integer(i4b), parameter :: itmax=200
real(sp), parameter :: stpmx=100.0_sp,eps=epsilon(p),tolx=4.0_sp*eps
integer(i4b) :: its
logical :: check
real(sp) :: den,fac,fad,fae,fp,stpmax,sumdg,sumxi
real(sp), dimension(size(p)) :: dg,g,hdg,pnew,xi
real(sp), dimension(size(p),size(p)) :: hessin
fp=func(p)
g=dfunc(p)
call unit_matrix(hessin)
xi=-g
stpmax=stpmx*max(vabs(p),real(size(p),sp))
do its=1,itmax
iter=its
call ckap(p,fp,g,xi,pnew,fret,stpmax,check,func)
fp=fret
xi=pnew-p
p=pnew
if (maxval(abs(xi)/max(abs(p),1.0_sp)) < tolx) return
dg=g
g=dfunc(p)
den=max(fret,1.0_sp)
if (maxval(abs(g)*max(abs(p),1.0_sp)/den) < gtol) return
dg=g-dg
hdg=matmul(hessin,dg)
fac=dot_product(dg,xi)
fae=dot_product(dg,hdg)
sumdg=dot_product(dg,dg)
sumxi=dot_product(xi,xi)
if (fac > sqrt(eps*sumdg*sumxi)) then
fac=1.0_sp/fac
fad=1.0_sp/fae
dg=fac*xi-fad*hdg
hessin=hessin+fac*outerprod(xi,xi)-&
fad*outerprod(hdg,hdg)+fae*outerprod(dg,dg)
end if
xi=-matmul(hessin,g)
end do
call nrerror('dfpmin: too many iterations')
end subroutine dfpmin
end module
I do not see where it could be defined onece again??
In module izvod you declare DFUNC as a generic interface (and module procedure). In module minmod, which uses izvod, you declare DFUNC as an external array (I am not sure that's what you intended - the syntax you used is not appropriate for declaring a function.)
I would suggest deleting the declaration in minmod so you'll pick up the generic from izvod - this seems to be what you want.
milenko1976
Thanks Steve.
This can be compiled.
