error LNK2019
mbehzad
I am going to compile a code on 64-bit windows system by IVF 11.0.0 and I got the following error in linking. Note that I don't have any problem with compiling on the 32-bit system.
"k3prep.obj : error LNK2019: unresolved external symbol GMOVA2 referenced in function DRV"
"k3prep.obj : error LNK2019: unresolved external symbol GLINA2 referenced in function DRV"
I am wondering if anyone could give me a help on that.
TimP
Assuming those routines are present in your source, the first thing to look for is compile errors there.
Another possibility is that you have not recompiled the routines GMOVA2 and GLINA2 with the 64-bit compiler. If the linker sees 32-bit objects or libraries for those routines, you'll see exactly this error.
