error accessing section of array
DavidWhite
Geschätzter Beitragender II
2.085Aufrufe
Using XE2017 with the shell version of VS, I am getting a subscript 0 error on accessing an array section.
I am referring to TFLOW(NOSD(1:6)).  When I attempt to display this in the debugger, it is also returning invalid subscript, while the individual references are all good:
        tflow(nosd(1:6))     Subscript out of range
-        nosd(1:6)    (1:6)    INTEGER(4)
        nosd(1)    45    INTEGER(4)
        nosd(2)    46    INTEGER(4)
        nosd(3)    47    INTEGER(4)
        nosd(4)    48    INTEGER(4)
        nosd(5)    49    INTEGER(4)
        nosd(6)    50    INTEGER(4)
-        tflow(45:50)    (45:50)    REAL(8)
        tflow(45)    37.1799413678762    REAL(8)
        tflow(46)    182.845277103799    REAL(8)
        tflow(47)    1.90446078777313    REAL(8)
        tflow(48)    1.36296749114990    REAL(8)
        tflow(49)    4.99094438552856    REAL(8)
        tflow(50)    0.000000000000000D+000    REAL(8)
Why is tflow(45:50) OK while TFLOW(NOSD(1:6)) is not, even though the values of NOSD(1:6) are 45, 46, ... 50?
This code has not been touched, and was previously working.
6 Antworten
DavidWhite
2.085Aufrufe
Ok, I have a work around.
instead of TFLOW(NOSD(1:NSEED)), I can use (TFLOW(NOSD(I)),I=1,NSEED)
Variable declarations:
INTEGER, PARAMETER :: NSEED = 6
INTEGER :: NOSD(NSEED)
REAL(KIND=KIND(0D0)) :: TFLOW(99)
Questions
1. Is my first version valid Fortran?
2. If not, why did it work before and not now?
3. Are there any compiler switches that previously made this work, which have changed to break it?
David
Xiaoping_D_Intel
Mitarbeiter
2.085Aufrufe
I think it is the same issue you reported in https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/698697
Xiaoping Duan
Intel Customer Support
DavidWhite
2.085Aufrufe
As far as the VS integration is concerned, it is the same issue.
While my comments earlier regarding runtime errors appears to be the same, somehow, I had previously got around this with XE2017, as far as I am aware.  I am now seeing runtime fatal errors since the array index is being computed as 0 instead of 45-50 as expected.
This has arisen now, in part, as I am trying to migrate to a new machine.
David
Xiaoping_D_Intel
Mitarbeiter
2.085Aufrufe
Using a small sample code based on your code lines I can get the runtime error only with "/check:bounds" options applied. I will open a bug report for it. As a workaround you can disable this option.
Xiaoping Duan
Xiaoping_D_Intel
Mitarbeiter
2.085Aufrufe
The bug report track ID is DPD200415725.
Xiaoping Duan
DavidWhite
2.085Aufrufe
Xiaoping Duan,
Thank you for that resolution for this issue.  I have confirmed that this array bound issue no longer arises when bound checking is turned off. Over the last few weeks, it is probable that I have only built the Release version of my code, which did not include bounds checking.  This is how I have been able to run with XE2017 and not have the problem arise.
David
Antworten
