error in dnls1.for
Omid_L_
When I compile the dnls1.f, I encountered these errors:
1>------ Build started: Project: Console16, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Fortran Compiler 10.1.030 [IA-32]...
1>dqrfac.for
1>dfdjc3.for
1>d1mach.for
1>xersve.for
1>xerhlt.for
1>i1mach.for
1>dwupdt.for
1>dmpar.for
1>xgetua.for
1>dckder.for
1>xermsg.for
1>j4save.for
1>fdump.for
1>dnls1.for
1>C:\...\Console16\dnls1.for(691) : Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. [ERR]
1>C:\...\Console16\dnls1.for(701) : Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. [ERR]
1>C:\...\Console16\dnls1.for(773) : Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. [ERR]
1>C:\...\Console16\dnls1.for(787) : Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. [ERR]
1>compilation aborted for C:\...\Console16\dnls1.for (code 1)
1>
1>Build log written to "file://C:\...\Console16\Debug\BuildLog.htm"
1>Console16 - 5 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Can anyone help me?
you can download the source code from this link:
http://netlib.org/cgi-bin/netlibfiles.pl?filename=/slatec/src/dnls1.f
Thanks in advance
This is an error in the source code, but is the kind of error that most compilers did not detect. The error message is quite explicit. When I try to look at the file you linked to, the line numbers don't match up so I can't be too sure, but it is an error to pass a scalar to a routine where the corresponding dummy argument is an array. If you don't want to fix the error, you can hide the message by turning off Diagnostics > Check Routine Interfaces.
Omid_L_
Thank you very much, the previous problems have been solved, but I encountered nother problems!!!
I would appreciate if you could help me to solve these problems.
1>dqrfac.for
1>dfdjc3.for
1>d1mach.for
1>xersve.for
1>xerhlt.for
1>i1mach.for
1>dwupdt.for
1>dmpar.for
1>xgetua.for
1>dckder.for
1>xermsg.for
1>j4save.for
1>fdump.for
1>dnls1.for
1>denorm.for
1>xerprn.for
1>xercnt.for
1>dqrslv.for
1>Linking...
1>libifcoremt.lib(for_main.obj) : error LNK2019: unresolved external symbol _MAIN__ referenced in function _main
1>Debug\Console16.exe : fatal error LNK1120: 1 unresolved externals
1>
1>Console16 - 2 error(s), 0 warning(s)
Thank you very much
NETLIB is a library of routines, there is no main program. You created your project as a Console application, which needs a main program (that presumably calls one or more NETLIB routines.) Add a main program.
Or, create a new project of type Library > Static Library, and add the NETLIB sources to it.
Omid_L_
Thank you very much Steve.
