29275 Discussions
error not detected unless -warn all is given
warpino
Hi all,
I am debugging a friend's code. At some point he calls a subroutine with the wrong number of arguments, actually he gives more actual arguments than dummy ones. I didn't spot the error until I used the -warn all option to compile. Is this the expected behaviour?
Using Intel Fortran Compiler for Intel64, Version 15 on Linux CentOS 6
Thanks in advance,
NL
jimdempseyatthecove
The -warn all option generates interfaces and checks interfaces. The Fortran compiler cannot verify calling arguments for subroutines and functions that do not have/use interfaces. Subroutines and functions contained in modules have interfaces by default, Those non-module subroutines and functions do not have interfaces (though some checking could potentially be performed in the IPO phase).
Jim Dempsey
