Dear experts,
I have downloaded a version of intel fortran composer for a test from intel website, but ran into a problem. And below is what I have done:
1. Download w_fcompxe_intel64_2011.11.344 and install on my Windows 7 computer. And I have vs2010 installed on my computer.
2. Go to start -> all programs -> intel parallel studio xe 2011 -> parallel studio xe 2011 with vs2010, then the studio window was opened
3. Go to new project, select intel visual fortran\\console application\\main program code from the available templates. Then I saw the source code to print ‘hello world’
4. Go to build and rebuild the solution , an error message return as “intel visual fortran for win 32 not installed”
Could anyone give me a solution to this issue? Many thanks.
So, choose one of the following:
1) Go back to the Intel Software Registration Center, download and install w_fcompxe_novsshell_2011.11.344.exe (the one that says it is for 32-bit/64-bit development).
2) In Visual Studio, select Build > Configuration Manager. Select New for the Active Solution Platform - it should then create an x64 configuration for you.
thanks a lot for you explaination. i will try it now.
