I am gettingan error in Intel Visual Studio: error #8000: There is a conflict between local interface block and external interface block [fnc]. It points at the line where I first call the function fnc. Surprisingly, the code runs perfectly on the older Compaq Visual Fortran without that mistake.
PROGRAM nwSpGr_demo
!INCLUDE 'link_fnl_shared.h'
!% nwSpGr_demo: test & demo for nwspgr
! USE nwspgr_mod
IMPLICIT NONE
INTEGER(4) :: DD,kmax,simnum
CHARACTER(3) :: tpe
REAL(8),ALLOCATABLE :: xx(:,:),ww(:)
REAL(8),ALLOCATABLE :: x(:,:),w(:,:),g(:,:),sim(:)
REAL(8) :: trueval,SGappr(1,1),SGerror(1,1),Simerror
INTEGER(4) :: kk,nn,r
INTERFACE
FUNCTION fnc(x1)
IMPLICIT NONE
! INTEGER(4) :: n1,d
REAL(8),INTENT(IN):: x1(:,:)
REAL(8) :: fnc(size(x1(:,1)))
END FUNCTION fnc
END INTERFACE
WRITE(*,*) 'Max k:'
READ(*,*) kmax
WRITE(*,*) 'Dimension D:'
READ(*,*) DD
WRITE(*,*) 'String :'
READ(*,*) tpe
ALLOCATE(xx(kmax**DD,DD),ww(kmax**DD))
WRITE(*,*) 'Number of simulation repetitions:'
READ(*,*) simnum
ALLOCATE(sim(simnum))
CALL RANDOM_SEED(PUT=(/ 123456789,412648571 /))
CALL RANDOM_NUMBER(xx)
trueval=sum(fnc(xx))/dble(kmax**DD)
DO kk=1,kmax
! CALL nwspgr(tpe,DD,kk,nn,xx,ww)
CALL RANDOM_NUMBER(ww)
WRITE(*,*) 'number of nodes:'
READ(*,*) nn
ALLOCATE(x(nn,DD),w(nn,1),g(nn,1))
x=xx(1:nn,1:DD)
w(1:nn,1)=ww(1:nn)
g(1:nn,1)=fnc(x)
SGappr = matmul(transpose(g),w)
SGerror = sqrt((SGappr - trueval)**2)/trueval
sim = 0.0d0
DO r=1,simnum
CALL RANDOM_NUMBER(x)
g(:,1)=fnc(x)
sim = sum(g(:,1))/(max(1,size(g(:,1))))
END DO
Simerror = sqrt(sum((sim(:)-trueval)**2)/(max(1,size(SIM(:)))))/trueval
WRITE(*,*) 'Number of nodes:'
WRITE(*,*) nn
WRITE(*,*) 'SG error='
WRITE(*,*) SGerror
WRITE(*,*) 'Sim. error='
WRITE(*,*) Simerror
DEALLOCATE(x,w,g)
END DO
END PROGRAM nwSpGr_demo
! integrand: some function that evaluates g(x): (R times D)->(R times 1)
FUNCTION fnc(x1)
IMPLICIT NONE
REAL(8),PARAMETER :: pi=3.14159265359d0
INTEGER(4) :: i
DO i=1,size(x1(:,1))
fnc(i) = product( exp(-(x1(i,:)/2.0d0)**2 / 2.0d0)/2.0d0/sqrt(2.0d0*pi))
END DO
END FUNCTION fnc
I would appreciate any suggestions.
PROGRAM nwSpGr_demo
! USE nwspgr_mod
IMPLICIT NONE
CHARACTER(3) :: tpe
INTERFACE
FUNCTION fnc(x1)
IMPLICIT NONE
END FUNCTION fnc
END INTERFACE
WRITE(*,*) 'Max k:'
READ(*,*) kmax
READ(*,*) DD
READ(*,*) tpe
READ(*,*) simnum
DO kk=1,kmax
READ(*,*) nn
x=xx(1:nn,1:DD)
w(1:nn,1)=ww(1:nn)
g(1:nn,1)=fnc(x)
sim = 0.0d0
DO r=1,simnum
g(:,1)=fnc(x)
END DO
WRITE(*,*) nn
WRITE(*,*) SGerror
WRITE(*,*) Simerror
DEALLOCATE(x,w,g)
END DO
FUNCTION fnc(x1)
IMPLICIT NONE
INTEGER(4) :: i
END DO
END FUNCTION fnc
The error message is coming from an interface consistency checker that CVF didn't have. However, in this case, it is not correctly handling the case of the function returning the array result with an expression bound.
There are two obvious alternatives:
1. Remove the INTERFACE block and move FNC to be a CONTAINed routine, so that the end of the code would look like this:
I prefer the first alternative, as I consider writing INTERFACE blocks for Fortran code to be poor style.
I will report this problem to the developers. The issue ID is DPD200148870. Thanks for bringing it to our attention.
[plain]DEALLOCATE(x,w,g)2. Right click on the Fortran project. Select Properties > Fortran > Diagnostics. Change "Generate Interface Blocks" and "Check Routine Interfaces" to "No".
END DO
contains
FUNCTION fnc(x1)
IMPLICIT NONE
INTEGER(4) :: i
END DO
END FUNCTION fnc
END PROGRAM nwSpGr_demo[/plain]
