29413 Discussions
error stop quiet=true generates calls
foxtran
New Contributor III
Considering the following code:
subroutine test_quiet(stat)
  implicit none
  integer :: stat
  if (stat > 0) error stop 1, quiet=.true.
  if (stat == 42) print *, 'unreachable'
end subroutine test_quiet
that is compiled as follows:
ifx test.f90 -O3 -S
 the resulting code has `callq for_error_stop_quiet@PLT` that can be avoided since
If QUIET= appears and the
scalar-logical-expr has the value true, no output of signaling exceptions or stop code shall be produced
from Fortran 2023 Standard (11.4 STOP and ERROR STOP statements)
Steve_Lionel
That's correct. ERROR STOP always terminates execution - the difference between it and STOP (which also has QUIET=) is that ERROR STOP terminates all images in a coarray application.
foxtran
New Contributor III
Hmm... There is no unreachable call after quiet stop (at IR level), while it should be.
foxtran
New Contributor III
Sorry, I misread standard. Looks like it states that execution is still terminating, but in silent way (no output to IO).
Steve_Lionel
