29649 Discussions
error while loading shared libraries: libcxa.so.5 using Intel Fortran 9.1
tgederberg
I am having a problem using the Intel Fortran compiler (version 9.1).
During the build process of a program, I am getting the following error:
ifort -o obj/spice/tobin/tobin.o -c -O2 -extend_source -assume byterecl -save -zero -module ./obj -Isrc -Iobj spice/toolkit/src/tobin/tobin.f
Building exe/tobin
"/users/orbfcs/otis4/exe/tobin" "ephem/astcom_ephemdata.xsp"
/users/orbfcs/otis4/exe/tobin: error while loading shared libraries: libcxa.so.5: cannot open shared object file: No such file or directory
scons: *** [ephem/astcom_ephemdata.bsp] Error 127
scons: building terminated because of errors.
libcxa.so.5 is in /app/intel/intel_fc_91/lib and I have LD_LIBRARY_PATH set to /app/intel/intel_fc_91/lib:
% echo $LD_LIBRARY_PATH
% ls $LD_LIBRARY_PATH
crtend.o libcxaguard.a libifcoremt.a libirc.a
crtxi.o libcxaguard.so libifcoremt.so libirc.so
for_main.o libcxaguard.so.5 libifcoremt.so.5 libirc_pic.a
icrt.internal.map libguide.a libifcoremt_pic.a libirc_s.a
icrt.link libguide.so libifport.a libirc_s_pic.a
libcprts.a libguide_stats.a libifport.so libompstub.a
libcprts.so libguide_stats.so libifport.so.5 libsvml.a
libcprts.so.5 libifcore.a libimf.a libsvml.so
libcxa.a libifcore.so libimf.so libunwind.a
libcxa.so libifcore.so.5 libipgo.a libunwind.so
libcxa.so.5 libifcore_pic.a libipgo_pic.a libunwind.so.5
When I execute ldd on the executable (tobin) created, I get:
% ldd tobin
libm.so.6 => /lib/tls/libm.so.6 (0x00b5c000)
libcxa.so.5 => /app/intel/intel_fc_91/lib/libcxa.so.5 (0x55014000)
libunwind.so.5 => /app/intel/intel_fc_91/lib/libunwind.so.5 (0x55039000)
libc.so.6 => /lib/tls/libc.so.6 (0x00a25000)
/lib/ld-linux.so.2 (0x00a0b000)
Can anyone help? I'm stumped. Thanks.
TimP
Does your build script open a new shell without setting the ifort environment?
tgederberg
No.
tgederberg
Hi, I asked this question last week but have not received much feedback. I am having a problem using the Intel Fortran compiler (version 9.1).
Building exe/tobin
% ldd tobin
tgederberg
Well, the problem has been fixed. We are using SCons to do the build rather than make and for some reason SCons was igoring the LD_LIBRARY_PATH. The sys admin just added the Intel library to the system path and now everything works fine. Not sure why SCons was ignoring the LD_LIBRARY_PATH setting though.
