29633 Discussions
error6122, pointer function in submodule
lauhwa
Recently I try to use submodule. But My compiler return a error of code 6122. There is a module and its sub module.
  module nonuni
  implicit none
  interface
  module function get_subarray(a,i,j)
  implicit none
  real,target::a(:)
  integer::i,j
  real,pointer::get_subarray(:)
  endfunction
  end interface
  endmodule
  submodule(nonuni) nonunis
  implicit none
  contains
  implicit none
  real,target::a(:)
  integer::i,j
  get_subarray=>a(i:j)
  endfunction
  end submodule
  implicit none
  contains
  implicit none
  real,target::a(:)
  integer::i,j
  endfunction
  end submodule
Then the compiler returned
error #6122: The characteristics of the separate module procedure differ from those specified in the separate interface body. [GET_SUBARRAY].
Then I tried another form.
  module nonuni
  implicit none
  interface
  module function get_subarray(a,i,jresult(asub)
  implicit none
  real,target::a(:)
  integer::i,j
  real,pointer::asub(:)
  endfunction
  end interface
  endmodule
  implicit none
  contains
  implicit none
  real,target::a(:)
  integer::i,j
  asub=>a(i:j)
  endfunction
  end submodule
It was compiled successfully.
Barbara_P_Intel
The bug described in this thread is fixed in the latest compiler release, 2021.3.0. I just tried it.
Please download it and confirm.  Let me know what you find.
Arjen_Markus
This looks like a bug in the Intel Fortran compiler. gfortran 10.2.0 accepts the code and I see no difference between the interface in the module and the actual code in the submodule.
Barbara_P_Intel
I filed a bug report on this, CMPLRLLVM-25800. I'll post here when there's a fix.
Barbara_P_Intel
