29280 Discussions
exe file deleted after call / program stops at different points
Stefan_S_5
Hi everyone
our software product was developped through years. xe composer and various predecessors are great tools. Since two days i have serious problems with xe composer:
after compiling and linking in debug or release mode, the program stops at various points in the code. Calling the program (release mode) from a command line will even delete the exe file after the call.
i do not have any idea what is going on. The source code was not changed radically. Even restoring previous versions of the source code does not affect this strange behaviour. Neither Visual Studio nor XE has been updated throught the last week.
Does anyone have any idea what is going on or what i could do?
G
Stefan
IanH
Check the behaviour and configuration of any virus scanner on the machine.    Sometimes they can get a little over-enthusiastic about protecting you from your own programs.
jimdempseyatthecove
IanH may be correct. Too many AV programs went to Whitelisting. Your brand spank'n new program isn't on their whitelist. Consider tuning off a scan of your output folder(s).
You can also check the build log to see where the .exe is actually being placed. Maybe something has changed (e.g. a new configuration or platform)
Jim Dempsey
Stefan_S_5
have been out for a few hours...
Thank you very much for the hint - you were right! I found my exe files in the quarantine of de AV Scanner and thus I will have to whitelist my program... and be happy again!
Stefan Sutter
