exe keeps disappearing
Gary_Hampson
Einsteiger
970Aufrufe
I thought I was losing my mind, but, on careful inspection I am finding that .exe files (using visual studio 2008) simply vapourise off my machine after a day or so or sometimes more.
I have no idea if I have inadvertantly set something in vis s to eat my exe's or whether its another unhelpful vista feature.
Has anyone any ideas??
Gary
6 Antworten
Steven_L_Intel1
Mitarbeiter
970Aufrufe
On my home machine, I found that my antivirus software was doing this on occasion. I told it not to scan my projects folder. Check your antivirus program's activity log.
jimdempseyatthecove
Geehrter Beitragender III
970Aufrufe
What does the AV program report to a log file what it (thought it) found in the .exe file?
This issue, and a copy of the .exe file, should be brought (sent) to the attention of the AV vendor. The three reasons I can think of are
1) actual virus hidden in .exe (may have come in with a library you are linking with)
2) unintended false positive in .exe
3) intended false positive in .exe
Jim Dempsey
Steven_L_Intel1
Mitarbeiter
970Aufrufe
The AV program noticed that it was a newly created, unsigned EXE that it had not seen before from other users. For the average user this would be suspicious and its default action is to quarantine the EXE. It did so silently, which I suppose was perhaps not the best choice.
jimdempseyatthecove
970Aufrufe
So add to the list
4) unsigned .exe with AV instructed to quarantine unsigned .exe (.dll, .com, ??)
So this (in your case) was a ligitimate action taken by your AV (although not what you initially expected as a developer).
Jim
grtoro
Einsteiger
970Aufrufe
If you are using Norton AV products, you may be interested in reading the following thread:
http://community.norton.com/t5/Norton-Internet-Security-Norton/SONAR-is-deleting-programs/td-p/160660
Many people have complained about this problem. To make matters worse,NAVsometimes comes back and deletes the same file again, even if told to ignore it.
Gabriel
Steven_L_Intel1
Mitarbeiter
970Aufrufe
Indeed, it was Norton Internet Security I was referring to above. I added the folder for my development area to the "exclude" list and have not seen the problem since. I read through that whole thread (and added my own comment). While I like the Norton tools, this particular behavior irks me.
Antworten
