execute_command_line
Oivind_Moen
Hello
I would like to execute_command_lines from inside a intel Fortran 11 program. Is there such a command execute_command_line for MS dos commands?
There are several. SYSTEMQQ and RUNQQ are the two I suggest you look at - the difference is in whether the program waits for the command to finish. Another alternative is the Windows API routine ShellExecute, which has some advantages. You can read about SYSTEMQQ and RUNQQ in the compiler documentation - both require that you add USE IFPORT to the program unit that calls the routine. ShellExecute you can read about here. And if you really want to get "down and dirty", there is always CreateProcessEx.
What sort of command do you want to run?
Oivind_Moen
Thank you a lot.
I will try this. The command I plan to execute is opc with some parameters.
It is used to read some process values from a server used for process control via openOPC ( open OLE for process control).
I do not know of any direct calls to read the OPC values and write values to the OPC interface via FORTRAN.
Thank you again for your help.
