29377 Discussions
Paralle studio VS2010 LNK1120: 1 unresolved externals
raoelite
I got when i was bulidning my rpject this error can u please tell me how to fix it..
TimP
Can't be answered without the information which should be in the build log
raoelite
Means what..can u explain in while i am builind it says like this..
raoelite
while i am bulinding my fortran file..it says like this...
raoelite
>------ Build started: Project: shell, Configuration: Debug Win32 ------
1>LINK : error LNK2001: unresolved external symbol _mainCRTStartup
1>.\Debug\shell.exe : fatal error LNK1120: 1 unresolved externals
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I am getting this error please tell to fix this error...
JohnNichols
Valued Contributor III
I beleive you have not changed the CVF code into Intel code. You need to right click I believe on the Solution explorer listing for the program and select the option to import the CVF code into the IVF format.
I think this is correct.
JMN
That could be - or the wrong project type was selected when creating the project.
If this was a CVF project, please read Migrating from Compaq Visual Fortran.
mecej4
To obtain an answer that is pertinent to your situation you need to give an adequate description of the problem -- with information on the OS and compiler used, the nature of the project, the build log (as TimP already stated), source code to reproduce the problem, if feasible.
Without such information, only speculative answers may be forthcoming, and it would be up to you to discern which, if any, are relevant.
