28381 Discussions
false positive: -stand f18 and IEEE_SELECTED_REAL_KIND
Diehl__Martin
There is a false positive when using IEEE_selected_real_kind in an initialization expression
warning #7416: Fortran 2018 does not allow this intrinsic procedure.   [IEEE_SELECTED_REAL_KIND]
  integer, parameter :: pReal = IEEE_selected_real_kind(15,307)
The following code (when compiled with 'ifort -stand f18 test.f90' illustrates this behavior
program test
  use, intrinsic :: IEEE_arithmetic
  print*, IEEE_selected_real_kind(15,307)
end program test
this is tested with ifort version 19.1.2.254
FortranFan
@Diehl__Martin ,
See this: https://community.intel.com/t5/Intel-Fortran-Compiler/Using-stand-f18-with-ISO-FORTRAN-ENV/m-p/1219155/highlight/true#M152298
My take is it's a compiler bug.
Please submit a support request at Intel OSC if you can.
Diehl__Martin
I found one more
  function isDirectory_C(path) bind(C)
    use, intrinsic :: ISO_C_Binding, only: &
      C_INT, &
      C_CHAR
    use prec
    integer(C_INT) :: isDirectory_C
    character(kind=C_CHAR), dimension(pPathLen), intent(in) :: path
  end function isDirectory_C
gives
~/DAMASK/src/system_routines.f90(25): warning #8893: The procedure used from a standard intrinsic module is not a standard intrinsic module procedure.   [C_INT]
      C_INT, &
~/DAMASK/src/system_routines.f90(26): warning #8893: The procedure used from a standard intrinsic module is not a standard intrinsic module procedure.   [C_CHAR]
      C_CHAR
Diehl__Martin
I have a shared license and cannot submit bugs. Would be great if anyone could do that for me
Barbara_P_Intel
I'll file a bug or two, but first can you give me a complete reproducer for the second issue?  This one is missing the module file and a function return value.
Thank you!
Diehl__Martin
Ok this one is a little bit more complicated. Actually, the warning comes from an interface.
I could not really design a 'minimal example', but the attached files reproduce the warnings
ifort -stand f18 -c prec.f90
ifort -stand f18 -c system_routines.f90
Barbara_P_Intel
Thank you for the reproducer.  I filed a bug on your behalf, CMPLRIL0-33441.  I'll let you know when it's fixed.
A major release of the Fortran compiler will be done before the end of 2020. Please don't look for the fix there.  The code freeze already happened.
Barbara_P_Intel
The false positives reported when using the -stand f18 compiler option are fixed in the Fortran compiler 2021.5.0 that was released as part of oneAPI 2022.1.   Please give it a try!
HAPPY HOLIDAYS!
Diehl__Martin
thanks, I can confirm that there is no false positive for both compilers (ifx and ifort).
Happy holidays!
