29279 Discussions
fglGetFloatv and fglGetBooleanv subroutines dropped
Giel_H_
I am wondering whether the subroutines fglGetFloatv and fglGetBooleanv are dropped from the include file ifopngl.f90 in the latest release of the IVF compiler (version 9..29).
I get build errors (no matching specific subroutine for this generic subroutine call).
Is ittrue that fglGetFloatv and fglGetBooleanv have been deleted?
Giel
No - if they were dropped, the error message would be different. More likely the arguments you are passing don't match the interfaces as declared. You can read the source of the module in the compiler's IA32INCLUDE folder.
fglGetFloatv takes two arguments. These can be a scalar integer(4) and an array of real(4), or a scalar integer(4) and an integer(4) containing a pointer to an array (this was an older implementation). fglGetBooleanv is similar except that the second argument can be an integer(4) array.
Giel_H_
Steve, I used the project properties Fortran Diagnostics Check Routine Interfaces setting 'Yes' to check the interfaces of an application and the compilation reported errorswith calls to fglGetFloatvand fglGetBooleanv. Since the ifopngl.f90 hasn't changed, there must have been something wrong with the arguments of fglGetFloatvand fglGetBooleanv.
The second argument in both calls contained %ref(param).
I changed it into loc(param).
That resolved the compilation errors with the Check Routine Interfaces setting set to 'Yes'.
Giel
Actually, that feature won't help you in this case. That works when you don't already have an explicit interface for the routine.
What is the declaration of "param"? My guess is that it is not the correct type for the routine.
Nothing has changed in ifopngl, but the compiler has had bugs fixed where it was improperly lenient in argument matching with generics.
Giel_H_
For the param in the fglGetFloatv I have two occurrences in two different subroutines; the declaration is eitherreal param(4) orreal param(16) .
For the param in the fglGetBooleanv the declaration islogical param(1).
Giel
Boolean isn't LOGICAL. It's INTEGER. Otherwise, there shouldn't be a problem.
