final procedure problem
qiu_n_
here is my code
module vector_class
implicit none
! Type definition
type,public :: vector
   private
   real, dimension(:), POINTER :: v
   logical :: v_allocated = .false.
contains
    procedure,public :: set_vector=>set_vector_sub
    procedure,public :: get_vector=>get_vector_sub
!    procedure,public :: clear_vector=>clear_vector_sub
   FINAL :: clear_vector
end type vector
private :: set_vector_sub,get_vector_sub,clear_vector_sub
contains
subroutine set_vector_sub(this,array)
   implicit none
   class(vector) :: this
   real,dimension(:),intent(in) :: array
   integer istat
   if(this%v_allocated) then
      deallocate(this%v,stat=istat)
   endif
   allocate(this%v(size(array,1)),stat=istat)
   this%v = array
   this%v_allocated = .true.
end subroutine set_vector_sub
subroutine get_vector_sub(this, array)
   implicit none
   real,dimension(:),intent(out) :: array
   integer array_length
   integer data_length
   integer istat
      array_length = size(array,1)
      data_length  = size(this%v,1)
      if(array_length > data_length) then
         array(1:data_length) = this%v
         array(data_length+1:array_length) = 0
      else if(array_length == data_length) then
         array = this%v
      else
         array = this%v(1:array_length)
      endif
   else
     array = 0
   endif
end subroutine get_vector_sub
subroutine clear_vector_sub(self)
   implicit none
   class(vector) :: self
   integer istat
   write(*,*) 'in finalizer .....'
   if(self%v_allocated) then
      deallocate(self%v,stat=istat)
   endif
end subroutine clear_vector_sub
end module vector_class
 program test_vector
 use vector_class
 implicit none
 type(vector) :: aa
 end program test_vector
following is compiler error :
vectorclass.f90(13): error #8338: A final subroutine name must be the name of a module procedure with exactly one dummy argument.   [CLEAR_VECTOR]
compilation aborted for vectorclass.f90 (code 1)
i not kown why is IT error ?
qiu_n_
IanH
As the message says... the final subroutine name must be the name of a module procedure... and it isn't.
Perhaps you meant
FINAL :: clear_vector_sub
Note that entities of the main program are usually not finalised - if you want to see `aa` finalised, make it a local entity of a subroutine or similar.
The dummy argument of a final procedure also needs to be non-polymorphic.
qiu_n_
my complier version ifort version 15.0.3
i modify my code :
to
but error is have
following is error message is :
vectorclass.f90(60): error #8339: The dummy argument of a final subroutine must be a variable of the derived type being defined and cannot be optional, pointer, allocatable, or polymorphic.   [THIS]
subroutine clear_vector_sub(this)
following is  source code::
module vector_class
implicit none
! Type definition
   private
contains
end type vector
contains
   implicit none
   integer istat
   endif
   this%v = array
   implicit none
   integer data_length
   integer istat
         array = this%v
      else
      endif
   else
     array = 0
   endif
   implicit none
   integer istat
   endif
 program test_vector
 use vector_class
 implicit none
 type(vector) :: aa
IanH
See the last sentence in reply #3.  The code still declares the dummy argument as polymorphic - using CLASS(vector).  It needs to be non-polymorphic - TYPE(vector)
qiu_n_
thank you! it‘s ok。
