29653 Discussions
Error install Fortran Compiler for Windows 2017
Yves_C_
While installing intel parrallel studio XE composer edition for Fortran Windows, I get this error :
Installation process failed : vs_isoshell.exe
Return error code : 1603
What must I do ?
Thanks for all
mecej4
It would be helpful if you can provide Information regarding the full name of the installer, your OS version and details of how far the installation proceeded before the error occurred. A log of the installation, if you can find the file, is probably on your machine and it would be useful if you can locate it and attach a Zip containing the file.
Yves_C_
The full name is  : Intel® Parallel Studio XE Composer Edition for Fortran Windows
The full name of the installer is : parallel_studio_xe_2017_update4_composer_edition_for_fortran_setup.exe
My O.S. is : Windows 7 enterprise Service Pack 1
I had, first to install Windows sdk v2013. Then I launched the installer and it stops at package 32/73.
I will try to find the log file.
