29564 Discussions
for_diags_intel.c:(.text+0x118f): additional relocation overflows omitted from the output
thaduong
Dear all experts,
I would like to compile a (quite large) program for molecular dynamics simulations with ifort.
The installation of the package l_cprof_p_11.1.059_intel64.tgz on my "Linux 2.6.31-16-generic x86_64" machine (with ubuntu 9.10) is OK (thank to M. Ron Green installation guide).
The compilations of the differents subroutines with the option "ifort -O3 -zero -save -pc64 -cm -w90 -w95 -mcmodel medium -shared-intel -DLinux -c *.f" are OK.
But at the end of the compilation (the linking process, I guess: "ifort -o toto.x all the files.o -lf2c -lm"), I have these error messages:
/opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__io_return':
for_diags_intel.c:(.text+0x9cf): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xa91): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xa9a): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xaeb): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
/opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__issue_diagnostic':
for_diags_intel.c:(.text+0xc0f): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xc74): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x1015): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x101e): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x10a6): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x10af): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.1/059/lib/intel64/libifcore.a(for_diags_intel.o)
I have not found any clue on the intel forum/documentation web sites about these errors.
Could anyone help me please ?
Thank you in advance,
Tap
Ron_Green
Quoting - thaduong
Dear all experts,
Tap
I believe you need -mcmodel=medium -shared-intel on the final link also.
If this doesn't work, move to mcmodel=large
ron
Ron_Green
Quoting - thaduong
Dear all experts,
Tap
ron
thaduong
ron
Dear Ron,
Thank you very much. It works perfectly now (even with the medium option).
Tap
