forrt1: severe <161>
rsvignesh82
My program compiles without any errors and warnings. However, while running it terminates and the error line reads "forrt1: severe <161> : Program Exception - array bounds exceeded"
Anyone has encountered this before?
Is the error message not clear? You have an error in your program that was detected at run-time - an array was indexed out of bounds. This message should be accompanied by more detail, including the name of the array variable, which dimension, the attempted index and the actual bound.Look for the consoke window or possibly a message box that may be behind the current screen.
rsvignesh82
Thank you for your response. I managed to solve the problem.
