I have a strange error that I am not sure how to deal with. I have a scientific numerical code that uses multiprocessors to run. If I run on a single process (CPU), the code can run essentially forever. However, when I use multiprocessors, e.g. it crashes after a fixed number of 'iterations' (over a million, which is quite a lot), in this case it runs for a couple of days before crashing with error:
forrtl: error (78): process killed (SIGTERM)
Image PC Routine Line Source
libc.so.6 00000031EDACF3A7 Unknown Unknown Unknown
libopen-pal.so.5 00002AF51C68D6CF Unknown Unknown Unknown
libmpi.so.1 00002AF51BB098BD Unknown Unknown Unknown
libmpi.so.1 00002AF51BB36987 Unknown Unknown Unknown
libmpi_mpifh.so.2 00002AF51C1F3666 Unknown Unknown Unknown
zeusmp.time 0000000000450265 bvalemf2_ 672 bvalemf.f
I debugged the code and found that it stalls due to two possible calls:
1. MPI_WAIT
2. MPI_ALLREDUCE
What I noticed is that ALL the simulations crash after a fixed number of iterations. So, I believe that somehow MPI_REDUCE call fills up memory somewhere, and when that reaches maximum, the code crashes.
Here is my 'ulimit -a'
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 514818
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) unlimited
cpu time (seconds, -t) unlimited
max user processes (-u) 1024
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
I searched the net to see if others encountered anything similar, but so far I was unsuccessful in finding a solution.One suggestion was to compile with -heap-arrays, but this did nothing at all for this case. Any suggestion will be highly welcome.
Compilations options I used: /act/openmpi-1.7/intel/bin/mpif90 -w -FI -c -O2 -Wno-globals -traceback -fpe0 -heap-arrays -L/act/openmpi-1.7/intel/lib -ldl -lpthread -lmpi
and I run it with:
/act/openmpi-1.7/intel/bin/mpirun -n 16
I've seen reports of this behavior before. In all cases it was due to some sort of "watchdog" process killing programs it thought were "runaway".
Right, thanks for your reply. it is eventually killed by MPI_WAIT or MPI_ALLREDUCE. But what is the best way to prevent such a behavior? I have compiled with --CB (check bounds), I also tried with gfortran, with the same results but crash occurs earlier, after fewer although substantial number of iterations (Over a million iterations).
Talk to your system/cluster administrator. It's an outside process that is killing your job.
